Fuzebox install - BMW K1600 Forum : BMW K1600 GT and GTL Forums
post #1 of 31 Old 06-12-2011, 08:59 PM Thread Starter
sfoster's Avatar
Fuzebox install
Looking for a spot to install the Fuzebox for accessory power. It won't fit anywhere under the seat, so I found a spot on the right side under the fairing which houses the actuator for the panner locks.
There's a nice flat spot to use double sided tape and I was able to get a zip tie through the base plate.
Tapped switched power from the top box plug.
The one thing I had be careful of was the seat bumper to wire clearance. Here's a picture showing the wires routed around the bumper.
K1600GTL Silver - SOLD - Now F800GS
IBA # 42277
sfoster is offline
post #2 of 31 Old 06-12-2011, 09:20 PM
GM
Administrator
GM's Avatar
Looks good! I was doing some testing yesterday and was disappointed I couldn't fit it under the seat. In the location above, it does get wet. I found the inside of those covers covered in road dirt.
The switched power wire from the top case harness is the Red with black stripe.
Thanks for the pictorial! :gm
GM is offline
post #3 of 31 Old 06-13-2011, 02:01 AM
Being really ignorant about electrical stuff, this might be a dumb question..
But why install a fuzebox and then take switched power from what might be a circuit designed for a lightbulb kind of load - I am guessing the topbox isn't designed for heavy duty power?
I would have thought the Canbus system would complain if you add a couple of things to your fuzebox.
chrisjk is offline
post #4 of 31 Old 06-13-2011, 02:43 AM
cbdane's Avatar
He's just using the light signal to close the contacts on a relay to provide switched power. The main power lead goes straight to the battery.
My question is how hard will it be to replace a fuse on the road if you need to?
cbdane is offline
post #5 of 31 Old 06-13-2011, 04:00 AM
Thanks - that certainly makes sense!
chrisjk is offline
post #6 of 31 Old 06-13-2011, 09:07 AM Thread Starter
sfoster's Avatar
Three screws. Under the seat would have been the most accessible, but there is nowhere under the seat for it to fit. This was the second most accessible.
IBA # 42277
sfoster is offline
post #7 of 31 Old 06-14-2011, 10:47 AM
GM
Administrator
GM's Avatar
If you don't use the cover for the Fuzebox, it will fit under the cross bar behind the battery. I tried it.
GM is offline
post #8 of 31 Old 06-14-2011, 12:53 PM
Sorry About the ignorance! But what is a "fuzebox" and what it's utility? Again sorry, but ....
namorado is offline
post #9 of 31 Old 06-14-2011, 01:57 PM
elizabethmuir's Avatar
elizabethmuir is offline
post #10 of 31 Old 06-14-2011, 02:30 PM
GM
Administrator
GM's Avatar
It permits you to plug in all your electrical accessories without cutting into the bike's wiring harness and has a built in relay to shut power off when the power to the bike is turned off.
GM is offline
