The Unhappy K1600 Onwers' Thread: Problems, let's hear about yours - BMW K1600 Forum : BMW K1600 GT and GTL Forums
 3Likes
post #1 of 443 Old 07-10-2011, 05:39 PM Thread Starter
mingo's Avatar
We could use this thread to list our issues thus far:
Major issue:
The starter will spin, but the bike does not start. After a few tries, the solenoid clicks and the starter engages the motor and the bike starts. This has happened 3 times. One time, I had to hit the starter button 11 times. The other times, I had to try twice and then three times. This is definitely not confidence inspiring. It's not the battery, I checked. I'm not sure what I'm going to do about this, because telling the dealer about it isn't going to resolve it if the bike starts when it's in his shop.
Other issues:
My top case was shipped with the inner light non functioning. My dealer attempted to rectify this by ordering a new topcase light and wiring harness. After several attempts, the dealer determined that the top case wiring harness is wired wrong at the factory. And the replacement topcase wiring harness is also wired wrong. Furthermore, he also told me that the topcase lock is also wired backwards, it unlocks when the panniers lock and it locks when the panniers unlock. Since I've only used the panniers once, and ride 99% of the time with only the topcase, I did not notice this. He checked the voltage coming from the bike end of the harness and it's powered correctly.
Ipod drops out suddenly and says "No USB", this is a regular occurrence.
USB memory stick does the same
Nav IV GPS froze once only.
Since this is a new bike, let's hear from others with similar problems to see if there's a pattern, like we have established with the "No USB" issue, or a random issue, like my starter.
mingo is offline
post #2 of 443 Old 07-10-2011, 06:57 PM
Turn signal/High-Low beam switch not functioning. Reminiscent of the K13S issues. On order for 2 weeks, just came in.
DMC 2007 BMW R1200GS Adv Hack
2012 K1600GT
2014 R1200GS
jpalamaro is offline
post #3 of 443 Old 07-10-2011, 06:59 PM
Raaze12's Avatar
I haven't had any of the issues you listed happen with my GTL. Sorry to hear you ended up with a problem. What is your dealer saying?
'12 Mineral Silver K1600GTL!
Raaze12 is offline
post #4 of 443 Old 07-10-2011, 07:22 PM
Mingo, try refueling from a different place than where you usually go, and use throttle when trying to start the bike to see if that helps.
CGameProgrammer is offline
post #5 of 443 Old 07-10-2011, 07:39 PM
The only issue I have had was the Navigator IV quitting twice. I rubbed dielectric grease on the contacts. Worked on the Zumo 550 when it did the same thing.
Not having grease on the contact points led to little wear points where the contact touched the pad. It was seeing this that caused me to start adding the grease. The wear point might have been a small hole. But then, the GSA does vibrate a bit more than the K16.
Mayflower Society
Son of the American Revolution
post #6 of 443 Old 07-10-2011, 08:00 PM
azari's Avatar
Other than my SRCS BT issues, nothing to report...
'15 R1200RTW
Ham: ACLT ** GMRS: WQNZ623
Ex'es:
'12 K1600GT (#59)
'04 R1150RT (Wife's hacked rig)
azari is offline
post #7 of 443 Old 07-10-2011, 08:44 PM
Only the iPod issue otherwise flawless, some fine young man with alot of money dropped in one of the latest GTO's made me go and dust him tonight, then he couldnt believe an old guy on a BMW large but tour bike smoked him lol
Richard
2012 K1600Gtl Royal blue, in the "D"
Dynamic is the only way to ride
rmpplo is offline
post #8 of 443 Old 07-10-2011, 09:24 PM
Raaze12's Avatar
LOL! Those GTO's are sweet machines but they sure as heck won't do 0-60 in 3.2 sec, nor will they crack an 11 second quarter mile. I would have loved to have seen that! :gm
Raaze12 is offline
post #9 of 443 Old 07-10-2011, 09:30 PM
katnapinn's Avatar
Only problem I've had so far is not enough time to ride. (Dang Work)
Steve Shreeve
2012 K1600GTL
katnapinn is offline
post #10 of 443 Old 07-10-2011, 10:33 PM
Beekeeper's Avatar
The chrome trim pieces on both side boxes are coming loose on each end. Dealer has ordered new ones. In the mean time I took the worst one off and used a heat gun to bend it to match the box and 3M double sided taped it in place it is now fine but has a few hairline cracks you can see if you are up close and looking. The only other issue is the rear tire pressure monitor looses connection and reads zero and throws a warning light but this happens about 1% of the time.
-6- Pure***magic
Western Mass.
K1600GTL
Beekeeper is offline
