Access point for switched 12VDC near handlebars - BMW K1600 Forum : BMW K1600 GT and GTL Forums
 3Likes
  • 1 Post By JoeP
  • 2 Post By ResQU
post #1 of 6 Old 01-10-2017, 02:05 PM Thread Starter
Boneman's Avatar
Wondering if anyone has any advice for an access point for switched power to wire in a 12VDC USB lead to power/charge my cell phone when it is in my RAM X-Grip mount in the handlebars (mounted at steering head roundel)? I currently don't have a FUZE block or any power distribution module installed.
I would like to permanently wire the USB cable in. Should I try to access the rear of the aux 12VDC socket in the right side panel?
~ Boneman
2011 K1600GTL
Motorcycle Instructor
Boneman is offline
post #2 of 6 Old 01-10-2017, 02:19 PM
garyculb's Avatar
USB Power
Boneman,
The photo’s in this link show where I installed my USB ( BMW K1600 TechMount ). The device can be a single or double USB source ( https://www.amazon.com/Astra-Depot-C...USB+motorcycle ). Some have positioned it down on the left side by the opening for the steering column. I have it connected to my PDM 60. Best,
Doc
garyculb is online now
post #3 of 6 Old 01-10-2017, 02:25 PM Thread Starter
Boneman's Avatar
Thanks, but I'm needing an actual switched 12vdc wire/access point(s) near the front of the bike to connect my USB cable to (e.g. headlight wire, ignition wire, etc.). I guess the USB cable will probably be long enough that the access point could be pretty much anywhere. Just want to know where to tap into.
BTW, why do you have two sat navs?
Originally Posted by garyculb View Post
Boneman,
Doc
~ Boneman
2011 K1600GTL
Boneman is offline
post #4 of 6 Old 01-10-2017, 08:29 PM
JoeP's Avatar
A few have used the low beam head light wire as a switched wire (search for CBDanes' driving lights). I wouldn't use that as the power, only use it as a switch for a relay (too many amps pulled will cause a fault). Run power from the battery to a relay. The headlight power could act as the switch to turn on the relay; then, relay (switched power) to your usb charger.
Boneman likes this.
If life gives you MELONS you may be dyslexic.
JoeP is offline
post #5 of 6 Old 01-11-2017, 03:25 AM
ResQU's Avatar
Why not just use the USB outlet in the lower storage box. It's switched power supply. I wouldn't leave the phone in there, but a long enough cable routed up along the fairing to your mount would work easy... Leaves the wires intact incase you change your set up...
Meese and ricky holco like this.
I honestly try to not ride faster than my guardian angel can fly , however....I know it's pooped by end of the ride
ResQU is offline
post #6 of 6 Old 01-11-2017, 10:13 AM
SmokinJoe's Avatar
You will find it hard to find switched DC at that area on modern CAN Bus (Controller Area Network) systems. The wires & clusters are VERY tight & small and generally carry 3-5 vdc data only.
As others suggested, relay off the headlight or fish an extended USB cable from the lower right glove box.
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTLE EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is online now
