Bike won't start - BMW K1600 Forum : BMW K1600 GT and GTL Forums
 8Likes
post #1 of 18 Old 01-01-2017, 08:30 PM Thread Starter
Erickwb's Avatar
Exclamation Bike won't start
I wonder if anyone can help me here.
I have a 2012 k1600gt very happy with the bike.
Last week I purchased a BMW motorrad navigator IV GPS, I plugged it in and it works like a charm. Connects to the main system, everything perfect.
This morning I went to start the bike... nothing. My house has a steep driveway, I tried to jumpstart... nothing.
Foolishly(?) I tried to jumpstart the bike with a set of leads from the car... still nothing.
Managed (with help) to get the bike back up the driveway and into the garage, pulled the battery out (10 months old nano- gel) put it on the charger it's currently reading 13.8v.
I'm hoping the gps thing is purely coincidental, but what the heck is going on?
Erickwb is offline
post #2 of 18 Old 01-01-2017, 08:45 PM
ResQU's Avatar
That's odd....I don't see how the GPS could draw down the battery. It does have its own battery that charges when the bike is on, but the bike shuts down the power to GPS when it's off. When you tried jumping, did it turn over and not start or did it not turn over either?
Erickwb likes this.
I honestly try to not ride faster than my guardian angel can fly , however....I know it's pooped by end of the ride
ResQU is online now
post #3 of 18 Old 01-01-2017, 08:54 PM Thread Starter
Erickwb's Avatar
When I tried to roll start, it did not even look like attempting a kick over. After the jump start failed, the bike went completely dead. I looked up the instruction manual, and read that using jumperleads to start the bike may result in damage. I hope I haven't killed the thing.
Erickwb is offline
post #4 of 18 Old 01-01-2017, 09:14 PM
ResQU's Avatar
That's where I was going with my question. I wanted to hear you say the bike turned over but would not start... Having nothing happen tells me that a circuit has been opened. Hopefully the CANbus system has a protective relay. I wish I knew more, good luck.
Erickwb likes this.
ResQU is online now
post #5 of 18 Old 01-01-2017, 09:21 PM Thread Starter
Erickwb's Avatar
Unfortunately my mechanic is still away for another week, so I may need to be patient. I just hope the bill doesn't have too many zeros!
ResQU likes this.
Erickwb is offline
post #6 of 18 Old 01-02-2017, 02:37 AM
What does the battery drop to underload?
Erickwb likes this.
"Enterprise" 2011 K1600 GT
The ultimate outback tourer.
Brick is online now
post #7 of 18 Old 01-02-2017, 03:02 AM
with a charged battery connected to the bike does
power on bring up lighting / horn / brake circuits, do the controls operate as normal
you depress the start button does the bike crank over (two green relays at the front of the seat, swap them over)
does the bike attempt to fire
what happens when you toggle the alarm
Erickwb likes this.
Also Rans ( Honda C90 & CD175 & CX500 & ST1100, Suzuki GT250 (J) & X7, Puch Maxi), Coveted Honda CBX, Yamaha Martini XS 1100 & FS1E, Kawasaki Z900, Z1000 & Z650, Quasar, Suzuki GT750
Mole999 is online now
post #8 of 18 Old 01-02-2017, 07:06 AM Thread Starter
Erickwb's Avatar
Turns out my battery of just 9 months old has died. It shows fully charged, but has no crank capacity.
I only hope that my attempt to jumpstart the bike from the car hasn't fried anything.
Erickwb is offline
post #9 of 18 Old 01-02-2017, 07:06 AM
Sounds like a main fuse/relay has blown, following the attempted jump start. I am as mystified as Mole on what else works, if anything, so maybe you can enlighten us idc. What was the battery voltage showing when first pulled?
Turning to the underlying issue, there just has to be parasitic drain going on somewhere. Always worth checking for fault codes before trying to second guess the problem. The usual culprits are after-market accessories, otherwise the SatNav or Alarm system seem the most likely.
Sometimes, usually on GSs in my experience, the power to the Nav cradle can go rogue & leave the unit & cradle permanently powered up - any over-run time after switching off the ignition should be no more than 1 minute max & can be adjusted through the canbus. Sometimes the cradle itself has corrosion on the contacts too allowing drain even when nothing is mounted, usually due to failing to replace the protective contacts cover &/or the '6' emblem. Here, I am not clear whether the bike has ever been run with a Nav IV installed in it's 4 years of life, until recently?
Then there is the alarm unit - always the provider of a small drain, but should drop into a sleep pattern after a day or so to help protect the battery. This needs expertise & time to check out.
Just a few thoughts. Good luck sorting the problem ........................ KEN
Erickwb likes this.
squibb is offline
post #10 of 18 Old 01-02-2017, 01:56 PM
Do you have a trickle charger even a simple one like the Battery Tender brand? While you are waiting for your mechanic to get back you could try putting the battery on that charger for a few days or until the green light comes on steady then give the bike another start up try.
Erickwb likes this.
2012 Mineral Silver GTL
