Question for Sargent seat w/backrest owners - BMW K1600 Forum : BMW K1600 GT and GTL Forums
post #1 of 12 Old 10-17-2019, 09:30 PM Thread Starter
woodbutcher's Avatar
How the heck do you remove the backrest? I just picked up a used seat and got the instructions off the Sargent site. It tells you how to insert the post and adjust the backrest, but nothing about removing the post. Pulling up just slide the pad and adjuster off.
Rusty Myers - Austin, TX
2009 BMW R 1200 GS Adventure
2013 BWM K 1600 GT
woodbutcher is offline
post #2 of 12 Old 10-17-2019, 09:44 PM
IIRC, reach down and feel for a flat springy piece of metal that is pressing against the seat stem/metal. Use your middle finger to spread the two pieces of metal apart and pull upward on the seat. If you have short fingers, you may want to use a flat tip screwdriver. Use a flashlight to look in the hole first to verify that I'm not giving you bad information. Good luck.
Best.
Darryl - Thanks for all you do!
RETIRED!
14BMWK1600GTL DGM
16BMWS1000XR Red
07HD FLHTCU Champion Trike
81CB750Bentforks$500
81 CB900 10speed 100HPOriginal $2.5K
81 CBX Orig 3Kmi 105HP $8K
81 CBX Frankenstein Trike $12K
1955 1st Chevy 3100 Pickup $30K
05 BMW X5
1990 Chevy 4x4
2001 Chevy Silverado 4x4
Coffintrailer $1K
Harleymarlboroman is offline
post #3 of 12 Old 10-17-2019, 09:48 PM
BMWGuy's Avatar
There are two detents on the post that need to be released before it can slide out.
Then remove the support block from the seat with the four screws.
If you're taking it off and not using it, I might be interested in it.
Good luck.
Joe
“Fate whispers to the warrior, 'You can not withstand the storm.'
The warrior whispers back, 'I am the storm.'
BMWGuy is online now
post #4 of 12 Old 10-18-2019, 10:21 AM Thread Starter
Best.
I can't find anything that matches your description. The support bar disappears into a narrow slot in the seat and there is nothing else there. I took the seat off and flipped it over and can't see a way to release it on the support bolt that is bolted on.
2013 BWM K 1600 GT
post #5 of 12 Old 10-18-2019, 10:24 AM Thread Starter
I'll keep you in mind. I just got the seat and figured I'd try out the back support for a bit and see if I liked it.
As far as removing it. It sounds like you are saying I need to remove the support block to get the bar released? All I want to do is pull the bar off and ride without a backrest to compare. I was hoping it was a simple process to pop the backrest off and on.
2013 BWM K 1600 GT
post #6 of 12 Old 10-18-2019, 11:08 AM
I'll dig mine out of the back room and remove the backrest. I'm sorry that my memory failed me. I probably was thinking about another seat that I have/had. Will post when I get a look at it later.
Best.
RETIRED!
14BMWK1600GTL DGM
16BMWS1000XR Red
05 BMW X5
1990 Chevy 4x4
Coffintrailer $1K
post #7 of 12 Old 10-18-2019, 11:32 AM
PLAGUE's Avatar
Tie a rope to it and attach the other end of the rope to a tree and accelerate quickly
Please post a video so others can benefit
There is thy gold, worse poison to men's souls,
Doing more murders in this loathsome world,
Than these poor compounds that thou mayst not sell.
I sell thee poison; thou hast sold me none.
PLAGUE is offline
post #8 of 12 Old 10-18-2019, 02:54 PM
I found this on the Sargent site for instructions. See if it matches what you have.
Front/rider backrest: https://system.na3.netsuite.com/core...73fe7&_xt=.pdf.
Rear/passenger backrest: https://system.na3.netsuite.com/core...b11a9&_xt=.pdf.
If those links don't work try this one and scroll down to where it has links to the backrest instructions on the left side of the page: https://www.sargentcycle.com/Seats-A...W-K1600GT-GTL/.
Hope that helps.
Ralphie is offline
post #9 of 12 Old 10-19-2019, 12:02 AM Thread Starter
Hope that helps.
Yep, those are the instructions I've already found. They talk about installing, but not removing the flat bar that is the support. I'd assume you just flex it slightly to free it from the detents and slide it up. But not on mine.
2013 BWM K 1600 GT
post #10 of 12 Old 10-19-2019, 10:27 AM
svfiat's Avatar
From the instructions to install the backrest it shows detents on the upright bar which would click into the support block. So I'm guessing that if you pull straight up wiggling the bar side to side it should pull out of the support block fairly easily.
svfiat is offline
