New review Sena SRL & Shoei Neotec 2 - BMW K1600 Forum : BMW K1600 GT and GTL Forums
post #1 of 30 Old 10-01-2018, 03:21 PM Thread Starter
Skyguyz's Avatar
4 of us just returned from a 6 day, 1350 mile journey with our 2018 BMW GTL's & 4 Shoei Neotec 2 helmets with 4 Sena SRL comm systems.There has been many opinions about the Sena SRL system and I posted about the painful pairing of the SRL's and I stand by what I wrote earlier. The lack of clear instructions from Sena made these units difficult to start out with. But as with any technology, you learn and adapt. The big "Fail" from Sena is the lack of instructional video on the company website. Sena has posted many videos about earlier products but they really need to update/include SRL video "How to's."
With that said here are the good and well as the bad opinions from myself concerning the Sena SRL:
The good:
- Once you figure the pairing sequence, they do not require "Re-pairing" them again.
- battery life was good and never did we require to stop and charge the SRL's despite some long riding days, (10 + hrs.)
- The intercom clarity is amazing and once you have your visor shut, it is like you sitting a car talking to each other.
- The music interruption and resumption of music when using intercom is flawless. ie: you talk, music fades out, you stop talking, music fades back in. Really a nice feature.
- unobtrusive on the Shoei Neotec 2.
Now the "So-so" review:
-The music quality suffers a bit from the lack of base. but really, these are not Apple iPods. I did not feel the music quality suffers to a point of not listening all day.
- The "Who's on first" group intercom scenario. it was a bit finicky to enter and leave group intercom and return to "One on
one"
intercom. This is due to mostly operator error and the smallish buttons.
- Price $259 per set before taxes and or shipping. A bit pricey.
- The 3 buttons can but a bit small with gloved hand but it's really a non-issue.
Now the Bad:
- Initial pairing sequence. Sena has done a horrible job of explaining the sequence and the combinations you can do to pair more than 2 headsets. *If you have 2 sets of 4 riders, ie: 2 couples then pair like this:
Couple 1 is A & B. Couple 2 is C & D.
Pair A with C then pair B with D then pair A with B then pair C with D.
*If couple 1 wants to talk only between themselves, then one center button push. If couple 2 wants to talk between themselves then one center button push. If any one wants a group intercom then 2 center button pushes will accomplish that. But remember, you must always 2 x push to exit and enter group intercom. And when you must center push once to regain one on one intercom the music sharing must be re-accomplished, (Hold - button until "Music sharing off" then hold - button again until "Music sharing on" is heard.)
- Sirrus sounds like crap. don't bother, its the bit rate of Sirrus that is the issue.
- Voice control is a battle that you will not win. Don't bother.
*I used a USB thumb drive with a ton of music on it plugged into the BMW K1600 GTL and it worked flawless. I gave up on Pandora, (Although it will work if you can pair it up early.)
*If using these on a BMW RT 1200 or K1600, DO NOT PAIR THE SENA TO THE GPS. This will only confuse the issue,
Pair your phone to the Sena then Pair the Sena to the BMW by using the "Media Selective paring." You will be able to listen to music from your phone, listen to music from USB or anything on the SRC button, (left side on GTL) and you WILL hear GPS directions as well. to do this:
1 Pair your phone to SENA by holding center button until "Phone pair" is heard. Pair the phone.
2- after that, hold center button and DO NOT LET GO until you hear "Configuration menu," *You will first hear "intercom pairing" Do not let go of center button until you hear "Configuration menu." The let go of center button and press the + button, (4th press) until you hear "Media Selective pairing." *Have your BMW in "BT pairing" on the dashboard to pair up.
After using the Sena SRL's for 6 days I am now fairly impressed with the clarity of the intercom, the phone features and the battery life. I would recommend the Sena SRL as a "Buy" if you have the Shoei Neotec2 and do long rides with others. Just don't expect the feature rich technology to be anything amazing g. For good solid intercom and easy music listen ing, its great. Forget the rest.
The Shoei Neotec 2 review:
I have had the Shoei Neotec 2 for about a month. I do a lot of riding, (7 bikes in stable) and it gets used almost everyday I am home. I am replacing it with the prior version, (Shoei neotec) and there is some great features in the new lid.
The good:
- It "Feels" lighter despite it being the same relative weight of the original Neotec.
- The venting is an improvement but I fail to feel a big difference. *The open/close mechanism on top works fine with gloved hand. C'mon you haters, it's a motorcycle thing. It's not that hard to open/close.
-Noise is significantly reduced due to the better bottom enclosure.
The "Stay up" feature of the flip up chin bar. I don't ride around a lot with the chin bar up despite it being D.O.T. approved.
-The positive lock when you lower the chin bar. The old Neotec did not always "Click" in. place when you lower the chin bar. The confidence of the new lid is much greater.
- The lack of "D" ring. It's about time! The best chin strap yet.
The Not so good.
- Shoei still uses the old method of securing the cheekpads with this thin plastic snap in place type fastener. Problem is that plastic is not bendable and you simple dread putting the check pads back in. Awful design.
- The price. Well I guess it's a matter of you get what you pay for and this is a quality lid.
Overall I am extremly happy with the a Shoei Neoptec 2. My GF has a new one also and has no complaints. Shoei designed a helmet that fits most mid-oval heads and it feels perfect when you put it on for the first time. No pressure points, nada.
Review of the 2018 BMW K1600 GTL.:
Perfect on a 6 day ride. Nothing even comes close.
*How to charge a SRL on a Shoei Neotec 2:
Sky
Skyguyz is offline
post #2 of 30 Old 10-01-2018, 06:25 PM
Ron Coleman's Avatar
Thanks, good review. Just curious about the sound quality/clarity if you used ear plugs (or not).
2018 K1600B: Forged Wheels; RDL Seat; 7Jurock Windscreen; Clearwater Betsys/Darlas; Ryanís Handlebar Risers; Wunderlich Stuff; Ilium Saddlebag Guards; HEX ezCAN; Bren Tune
ďCritical thinking...the last frontier.Ē
"Far better is it to dare mighty things, to win glorious triumphs, even though checkered by failure...than to take rank with those poor spirits who neither enjoy much nor suffer much because they live in the gray twilight that knows not victory nor defeat." Teddy Roosevelt
Ron Coleman is online now
post #3 of 30 Old 10-01-2018, 06:34 PM
reid's Avatar
Great review! Thanks. I was looking at the Shoei, but now I'm leaning toward the C3 Pro.
Yukon_Cornelius likes this.
Reid
2012 K1600GTL...Blue Metallic
USMC 71-75 (Semper Fi)
reid is offline
post #4 of 30 Old 10-01-2018, 06:54 PM Thread Starter
Skyguyz's Avatar
I have not tried the Shoei Neotec 2 with earplugs. I don't use them when I ride but....It "Feels" like ear plugs would fit fine.
Sky
Skyguyz is offline
post #5 of 30 Old 10-02-2018, 05:02 AM
DavidMcK's Avatar
I have the same setup, Shoei Neotec 2 and Sena SRL. What works for me is the Sena paired to the bike as phone 1 and the Sena paired to the Nav VI as phone 2. I don't listen to music on my phone, just a memory stick plugged into the bike or the bike radio and I ride one up.
I have just returned from a 3 day trip to the Lake District in England A friend of mine and I paired up on the trip, he has a Sena 20s. All worked well and I second Skyguyz's verdict on the Shoei and the SRL, the quality is excellent for both of them.
We will have the fun of setting up a group intercom the next time we meet up again with other mates.
A couple of points for me:
1. I find the buttons too fiddly (with gloves) and have been experimenting with voice control, its not too bad (it must understand a Northern Ireland accent). I was able to initiate intercom with my friend and it even liked the "Hello Sena, redial" command to return a phone call to my wife.
2. Once the volume was set, the combination of helmet and Sena meant I was not trying to increase or decrease the volume over a speed range of 50-80mph.
3. I use custom made ear plugs and loudness is OK. You can set the Audio boost on the Sena App.
All in all an excellent combination.
DavidMcK is offline
post #6 of 30 Old 10-03-2018, 10:58 PM
I just ordered both and received them a couple of weeks ago. This past weekend was the most riding I've done with it and over all very happy with the setup. There is definitely a learning curve but once you get the hang of what buttons you need to use, all is good. Voice control is working very well for me. You just have to be in standby mode first (no music playing) for it to respond. I have my phone paired directly to the SRL and voice control using SIRI is awesome! Music sounds good to me with the exception of SirusXM as everyone else has mentioned.
volfan615 is offline
post #7 of 30 Old 10-04-2018, 01:50 AM
1dragon's Avatar
Thanks for the review. I just returned from my first trip with my new Neotec 2. The helmet is just fantastic, no complaints. I wore it for two hours on local rides before wearing it for 8 plus hours straight. Very comfortable helmet.
I am contemplating the SRL, your review helps. I have the Sena 20S and have zero complaints with it, so I was a little hesitant on the SRL. I do like the cleaner formfactor of the SRL, your review probably just sealed the deal for me.
Matt S.
2018 K1600B- black beauty
2007 ST1300- silver bullet
1981 CB900C- blue bomb
1dragon is online now
post #8 of 30 Old 10-04-2018, 10:49 AM Thread Starter
Skyguyz's Avatar
Your welcome. it works for me!
Sky
Skyguyz is offline
post #9 of 30 Old 10-04-2018, 10:56 AM
iride4u's Avatar
I also have a Shoei Neotec 2 with a SRL. Overall I am happy with the helmet and the quality of the SRL. My only problem is I can't transmit through a Sena Freewire. Sena says that a software update is coming but they don't know when.
http://i826.photobucket.com/albums/z...psyffk7rzv.jpg
http://i826.photobucket.com/albums/z...pswzvlq5uf.jpg
Loveland, Colorado
2018 Honda Gold Wing Tour DCT
2018 Hyundai Tucson Limited
2015 R1200RTP
iride4u is offline
post #10 of 30 Old 10-18-2018, 06:57 AM
Thank you for the wonderful tutorial. It will surely save me a bunch of time. My wife and I just ordered a pair of these yesterday, and are really anxious to give it all a try.
aggieengineer is online now
