Front wheel bearing life? - Page 6 - BMW K1600 Forum : BMW K1600 GT and GTL Forums
 28Likes
post #51 of 57 Old 01-24-2019, 07:12 PM
Originally Posted by alstrickland55 View Post
If anyone wants a set of bearings, send me a PM. I thought I was ordering 2 bearing but I actually bought 2 lots of ten. I will sell a set (2 bearings) for $20.
U/I can be a real btch. Had an LPO on my first ship order 10 boxes of Kimwipes. He didn't realize that each box contained 100 cartons and each carton contained 1000 Kimwipes.
We had engineers coming up to the shop to look for rags for wiping down their equipment.
StephenV is offline
post #52 of 57 Old 01-24-2019, 08:57 PM
Originally Posted by rush21122 View Post
I nearly had a catastrophic failure on a highway 81 during a rain storm. ~50k on the bike when it happened. Since then I have vowed to change it every 12k out of an over abundance of caution. If I remember correctly was ~175 dollars to get replaced. I'll sleep better w/o the 175 dollars and with a new bearing. Different strokes I guess
25 dollars worth of bearings beats a thousand dollar headache.
I would be swapping them every 20k miles if not slightly less. They should be inspected often. If you live in or ride frequently in dirty, gritty environments bearing replacements should be often.
I had a similar experience with rear bearing failure on previous bike at 15k miles.
K16guy is offline
post #53 of 57 Old 01-24-2019, 09:00 PM
Originally Posted by StephenV View Post
Around 85k miles I started hearing a weird grinding sound coming from the front of the bike. It was very random and usually only a couple little bursts then silent... The first couple times I hear it was while riding through a gravel parking lot so I thought perhaps a rock was caught in the tread and scraping the inside of the front fender. With the fonr wheel in the air and while spinning the front tire, everything was smooth and silent. Since I was about 800 miles from home at the time, I just kept going.
When I got home I lifted the front wheel again and it was still spinning smooth and silent.
Then I removed the wheel.
This fell out.
My rear bearing failure was bad enough it had chewed through the retention ring and some if not most of the bearings.
K16guy is offline
post #54 of 57 Old 01-24-2019, 09:01 PM
Invest in a bearing puller and seating kit, it pays for itself and isn't that difficult although I've not tried it on this bike (yet).
Keep some bearing replacements on hand too!
K16guy is offline
post #55 of 57 Old 01-24-2019, 10:05 PM
I've had Beemers that have gone well over 100K miles with the original front wheel bearings. And I know of some that have failed far earlier than that.
Thus I check the front bearings at every tire change to ensure they're clean and roll smoothly.
Yes, these are a "wear item" but a properly deigned and properly installed sealed bearing should easily last for 100,000 miles or more, even in a harsh motorcycling environment.
I had three full wheel sets (front & rear & tires mounted) for the last IBR. Two of the front rims had ~20K miles, and one had well over 100K miles. All three front rims had brand-new bearings and seals installed by me prior to the Rally, using a special seating tool made in my friend's shop that set the bearings square and concentrated the force on the outer races only.
None of the old bearings felt bad on the bikes, but some of them were just starting to show some stiction when turned by hand. In that case it was worth it, as a bearing failure there could have thrown away the entire 11-day ride.
But changing bearings as often as tires is just kinda silly. And if they're not put in correctly and carefully, then you're likely hastening their failure...
post #56 of 57 Old 01-25-2019, 06:06 AM
My K1600GTL front failed at around 35,000 miles. I started to feel some front end vibration only on turns. I would stop and check for vibrations or something out of place. Nothing... I initially thought I had picked up some trash because it was smooth when the wheel was straight and not under a load.
post #57 of 57 Old 05-23-2019, 12:29 PM
My front wheel bearings today with 31k miles on them.
2015 R1200RT, Pirelli Angel GT II (A), Motul 5100 10W40, Mahle OC 306, V-Stream Z2463
Ed Harley is offline
