How do I remove the front wheel? - BMW K1600 Forum : BMW K1600 GT and GTL Forums
 41Likes
post #1 of 69 Old 09-09-2019, 09:35 PM Thread Starter
Evidently I'm an idiot. Seems like a pretty simple thing: take off the calipers losen the pinch bolts, unscrew the axle. I watch a video on this, doesn't seem too complicated. My axle just spins nothing seems to happen. What did I do wrong?
Sent from my Pixel 3a using Tapatalk
vistavette is offline
post #2 of 69 Old 09-09-2019, 09:39 PM
jryan19's Avatar
It should not spin unless the threaded bushing on the left side is loose. Check that first.
2018 Grand America
2013 GTL sold
PM me about my pullback risers.
Grand America & 1600 "B" Risers
https://stlouis.craigslist.org/mpo/d...030503692.html
GTL RISER PICS
https://stlouis.craigslist.org/mpo/d...044884162.html
See RAM MOUNT Pics
https://stlouis.craigslist.org/mpo/d...030504417.html
jryan19 is online now
post #3 of 69 Old 09-09-2019, 09:39 PM
Originally Posted by vistavette View Post
Evidently I'm an idiot. Seems like a pretty simple thing: take off the calipers losen the pinch bolt, unscrew the axle. I watch a video on this, doesn't seem too complicated. My axle just spins nothing seems to happen. What did I do wrong?
Keep the pinch bolt tight on the clutch side of the axle. It's the nut and needs to stay put. This will also allow you to reinstall the wheel in the same place side to side as the factory setting.
Gunnert, BMWGuy, WillH and 1 others like this.
1950 Chevy Pickup
Arizona Jim is offline
post #4 of 69 Old 09-09-2019, 09:40 PM Thread Starter
Hmmm more help needed. Everything on the left spins. Should I have not loosened the left pinch bolt?? I'm confused
post #5 of 69 Old 09-09-2019, 09:41 PM Thread Starter
Originally Posted by Arizona Jim View Post
Keep the pinch bolts tight on the clutch side of the axle. It's the nut and needs to stay put. This will also allow you to reinstall the wheel in the same place side to side as the factory setting.
Okay. I loosened the left side. Should I tighten that back up? I sort of tried that and the axle was pretty tight. How much pressure does it take to break the axle free?
post #6 of 69 Old 09-09-2019, 09:42 PM
The pinch bolts need to be tight 19nm. The axle is set at 50nm of torque so fairly tight at first. The caliper bolts are tightened to 28nm
vistavette likes this.
1950 Chevy Pickup
post #7 of 69 Old 09-09-2019, 09:45 PM Thread Starter
Thanks guys! I truly am an idiot, but you guys always save the day.
post #8 of 69 Old 09-09-2019, 09:48 PM
If you haven't already you will need to remove the fender to be able to get the tire/wheel out. When removing the calipers twist them side to side to push the pads back. This will also help when installing them. Don't forget to pump the brake lever after reassembly and before riding to reset the pads.
Once reassembled spin the wheel to make sure the ABS sensor isn't rubbing on the perforated disc. If so then you moved the wheel that way a little when the nut pinch bolt was loose. Loosen both pinch bolts and bump the wheel away from the sensor until there is a slight gap between it and the perforated disc.
After a couple front wheel removals you'll have it down pat.
1950 Chevy Pickup
post #9 of 69 Old 09-09-2019, 09:49 PM Thread Starter
Yep, did that. Thanks the reminder though
post #10 of 69 Old 09-09-2019, 10:04 PM Thread Starter
thanks for your help on this. I read the manual, but I guess I wasn't clear on the left side pinch bolt staying tight until I loosened the axle. I did watch a video who gave me the tips on rocking the calipers back and forth etc. Once I get the new tire on tomorrow I should be able to reassemble it, doesn't seem like it should be too much trouble, but be on the lookout for another post from me. thanks again.
