Babyís got new shoes... - Page 2 - BMW K1600 Forum : BMW K1600 GT and GTL Forums
post #11 of 22 Old 10-19-2019, 03:39 PM Thread Starter
Originally Posted by Mole999 View Post
Bridgestones come in two variants, the GT has stiffer side walls for the weight of the bike so are considered harder to mount. Are RS3s similar ?
I am not aware if rs3 has a gt version. These spooned on pretty easy in my opinion. Lots of lube and small bites with the spoons. The beads broke really easy on the stock tires.
I need to get a big allen wrench for that front axle and I still havenít figured out how to remove the valves. They arenít like all my other bikes/cars.
Fargo, ND
2018 GTL purchased 10/6/2019
post #12 of 22 Old 10-19-2019, 04:52 PM
Originally Posted by [email protected] View Post
Then I moved to the front and realized that I need an inside out socket to remove the front axle. Hmmm. A little weird and I didnít have any bmw tools yet. So I dug through my junk drawer and found a 22mm bolt and threaded a nut on and marred the end. Problem solved.
How did you get the proper torque on the axle upon reassembly?
StephenV is online now
post #13 of 22 Old 10-19-2019, 05:57 PM
Here is a universal front axle hex tool at Amazon https://smile.amazon.com/Jecr-17mm-M...1518497&sr=8-1
If you're talking about removing the valve core in your tire valve a standard removal tool will work. Yours may be in tight right now but I have several tools and they all work.
BMWGuy and [email protected] like this.
Arizona Jim is offline
post #14 of 22 Old 10-19-2019, 09:27 PM Thread Starter
By my well calibrated forearm? I probably didn't. I just gave it some kentucky windage based on the pressure it took to remove it. I will properly torque it tomorrow. BTW, what is the torque spec for that one?
Fargo, ND
post #15 of 22 Old 10-19-2019, 09:28 PM Thread Starter
Brilliant sir! Thanks for the advice!
Fargo, ND
post #16 of 22 Old 10-19-2019, 09:57 PM
BMWGuy's Avatar
... I need an inside out socket to remove the front axle. Hmmm.
This is the one I use: BMW Motorcycle Front Axle Tool
[email protected] likes this.
ďFate whispers to the warrior, 'You can not withstand the storm.'
The warrior whispers back, 'I am the storm.'
BMWGuy is online now
post #17 of 22 Old 10-20-2019, 12:29 AM
mglax13's Avatar
37 ft lbs for the axle
14 ft lbs for the pinch bolts
21 ft lbs for the caliper bolts
Live to ride. Ride for a living.
Work - 2018 H-D NYPD FLHP
Personal - 2013 BMW K1600GTL
Track - 2005 Suzuki SV650
mglax13 is offline
post #18 of 22 Old 10-20-2019, 12:32 AM
Not nearly as much as you might think... Seeing as how this value sets the "squeeze" pressure on the bearings, it is pretty important to get the torque on the axle right. Make it too tight and you will destroy your wheel bearings in short order.
Front Brake Caliper - T-45: 28 NM Torque - 20.65 ft lb
Pinch Bolt (ONLY LOOSEN RIGHT SIDE!) - T45: 19 NM Torque - 14 ft lb
Wheel Axle - 50 NM Torque - 36.88 ft lb
Front Fender - T-30
post #19 of 22 Old 10-20-2019, 12:41 AM
This is the hex tool I use. $7 delivered and uses a Ĺ" drive which is a perfect fit for my torque wrench.
https://www.amazon.com/gp/product/B004W82PGS/
post #20 of 22 Old 10-20-2019, 02:49 PM Thread Starter
Awesome! Thanks for the specs guys!
Fargo, ND
