Removal of B/GA Floorboards - BMW K1600 Forum : BMW K1600 GT and GTL Forums
post #1 of 22 Old 04-01-2019, 02:32 AM Thread Starter
robd1's Avatar
Send a message via Skype™ to robd1
I have been told by a number of people, including salesmen, that the floorboards are the reason for the GA being unstable in the wind and the reason why it has speed limitation set at 100MPH. I find the twitch quite un-nerving having come off a very stable RT LC. I can't quite compute this as the Bagger has floorboards but is limited at a higher speed. This seems to take the floorboards out of the equation and tends to implicate the top box. Has anyone taken the floorboards off and noted any improvement? If this improves the stability in wind it is a cheap, easy fix. The top box is a whole different ball game.
Nothing "succeeds" like a hungry canary.
robd1 is offline
post #2 of 22 Old 04-01-2019, 02:14 PM
The floorboards can affect airflow, but the top box will affect it more.
What tires are you running? Some brands are known to be more twitchy than others.
Also, I thought that doing over 100 mph in Australia is a Very Bad Thing, with massive penalties...
1dragon likes this.
'13 Dark Graphite Metallic K16GTLD
Some people see the gas tank as half empty. Some see it as half full. All I care is that I know where the next tankful is coming from . . .
post #3 of 22 Old 04-01-2019, 03:32 PM
BMWGuy's Avatar
Not to mention the Roo's that seem to come out of nowhere at the most inopportune times.
Joe
“Fate whispers to the warrior, 'You can not withstand the storm.'
The warrior whispers back, 'I am the storm.'
BMWGuy is online now
post #4 of 22 Old 04-01-2019, 03:50 PM
jryan19's Avatar
Some members have reported that changing the windshield cuts down on the movement in dirty air. I still have the standard shield so can't comment on that.
jukhako likes this.
2018 Grand America
2013 GTL sold
2009 GL 1800- 80k miles
PM me about my pullback risers.
Grand America & 1600 "B" Risers
https://stlouis.craigslist.org/mpo/d...864216884.html
GTL RISER PICS
https://stlouis.craigslist.org/mpo/d...864216172.html
See RAM MOUNT Pics
https://stlouis.craigslist.org/mpo/d...864218598.html
jryan19 is online now
post #5 of 22 Old 04-01-2019, 04:13 PM
jkriner's Avatar
I have a Grand America and have removed my top case many times. The top case affects the bike more than the floorboards do. I have ridden a couple thousand miles both ways and the bike is on rails with the box off. I have on a couple occasions, behind big rigs, experienced a slight back and forth wobble with the top case on. But I think all bikes will experience some wobble behind big rigs.
As others mentioned, there is a windshield that many are using that can eliminate the wobble with the box on. A Wunderlich vented shield, I believe.
firstime911 and jukhako like this.
Jesse Kriner - Hope Mills, NC
2018 Grand America - Black Storm Metallic
14 GTL, 05 LT, 85 K100RS
jkriner is online now
post #6 of 22 Old 04-01-2019, 06:54 PM
My B has no floorboards and it has a taller aftermarket windscreen - Firming up the suspension greatly improved the "twitchy" feel that I felt in the handlebars when in "truck wash".
I would not call what I felt "instability".
My '14 RT was better in "truck wash" than my B.
Current bike: '18 K1600B
Most recent former bikes:
'14 R1200RT
'13 F800GT
WillH is online now
post #7 of 22 Old 04-04-2019, 05:54 AM Thread Starter
robd1's Avatar
Thanks for your input. Both are very interesting and perhaps the topbox removal and the windscreen could be the way to go. Somebody also suggested the Bridgestone tyres could contribute but they are common to the B and the RT?
robd1 is offline
post #8 of 22 Old 04-08-2019, 10:58 AM
Scottanasek's Avatar
I have an 18 GA and a 18 GTL. I've removed the boards on the GA and it made zero difference. I've tested every configuration known to mankind to decrease the "wobble" in dirty air. I've found with a passenger it all but goes away completely. I don't know if I'm just getting used to it or something has changed on the bike, but it seems to be getting better the more miles it has on it (tires?). I assumed the instability was partially due to a shortened rake but I'm no engineer. Would love to hear if anyone changed tires and it helped? I'm surprised changing the windshield made a difference but also happy to hear it.
firstime911 likes this.
Scott Wanasek
Scottanasek is offline
post #9 of 22 Old 04-24-2019, 09:42 PM
Are those floorboards compatible with a 2012 GT?
Maurockstar is online now
post #10 of 22 Old 04-24-2019, 10:18 PM
I think they are, if you also use the newer factory engine guards.
Those engine guards show the same part number for 2017-on GTL and Bagger.
So unless the engine mount points changed, the parts should bolt up.
Note that you may have interference with the bodywork around the two lower cubby holes.
I believe on the Bagger and Grand America you get to choose floorboards or storage, but not both.
Maurockstar likes this.
Installing Passenger Floorboards - Difficult! Al Trujillo BMW K1600 General Discussions 6 02-09-2019 10:13 AM
Removing "B" Floorboards? Read this. bbolesaz BMW K1600 Accessories 16 12-21-2018 03:02 PM
Fuel tank removal "how to" and pics mneblett BMW K1600 Maintenance and Do-It-Yourself 23 09-01-2017 09:22 AM
Bushtec Hitch Installation – Rear Panel Removal mneblett BMW K1600 Accessories 5 09-11-2016 07:25 AM
Lower fairing removal for tip over bars greigster BMW K1600 General Discussions 2 04-16-2016 08:54 AM
