I was wondering the same. So big and heavy thought it might be impossible with out a huge hillis it not possible to pop start these bikes?
Sent from my SM-G970U using Tapatalk
Not if the voltage is low.is it not possible to pop start these bikes?
Battery was massive compared to the one I took out. Did get it jury rigged and bike started up. Now to repeat the whole process with the correct battery. UghI can't tell if the yt19bl-bs is correct. Looks too tall for the 2018.... Parts counter says it is correct.
Edit: yuasa says this is only good until the 2017 models. Uggg. There goes a whole day of charging.
They give you a car battery?I did go to my dealer. They gave me the wrong battery.
Do a load test to rule out the battery. Also check ALL the ground wires!Pulled in to work. Shut the bike off to fill the tire with air. Tried to start it - Christmas tree dash. Click and the whole bike shuts off and display restarts.
Seeing all kinds of weird warning lights: front light failure, severe engine fault, no key, DTC errors (not the one when the bike first starts).
I'm hoping it's just a battery thing. Bike dash says 11.9 V. Thoughts?
I think he's already confirmed the problem.Do a load test to rule out the battery. Also check ALL the ground wires!
TC
Bump starting worked great in days of old when carburetors were on everything. EFI requires battery voltage in order to function.is it not possible to pop start these bikes?
Which Dealer was it? Wild West or Gulf Coast? I live in Cypress area.I did go to my dealer. They gave me the wrong battery.
Jerry saves ✌I heard someone has acid to drop. Can I get in on that? It's been years.
Mancuso. Annoying to have to leave the bike sitting an extra day to charge a new battery but they made it right in the end.Which Dealer was it? Wild West or Gulf Coast? I live in Cypress area.
Nope. Apparently there is a difference in battery box size between the 2018 and 2017 MY and their system listed the larger battery for both MY.They give you a car battery?![]()
