I was getting ready for my commute to work this morning, got to the end of the street and noticed the check engine light. Bike seemed fine so I went a bit further, made it to work with no issues at all, bike seemed totally fine even though the light stayed on the whole way ( ~20 miles ).
When I came back to the bike 8 hours later, no check engine light, everything seems normal.
The previous owner had given me a GS-911 which I hooked up and did a scan. This was the bit that caused the light to come on I believe. Any ideas on what I should do next? As of now I have no light on for the last 20 miles.
Fault Code Value : 0x21F520
Fault Code Meaning : Electric fuel pump, short circuit to ground
Currently present : NO
Engine warning light (MIL) : NO
Frequency count : 1
Logistic (Healing) count : 39
Fault Code History :
Record number : 1
Odometer : 47422.8 mi
Absolute Time : 8278755
Engine RPM : 0 rpm
Speed : 1.4 mph
Battery voltage : 12.00 V
Fuel pump voltage : 11.74 V
In case it's helpful, the entire log is below. Thank you in advance as always!
AutoScan : -
Firmware Version : 1.70 - 0.243
Data pack Version : 219
Serial Number : GS1 009 535
Registration : Tim Brandall
Date : 2022-06-24 17:42:56
Bike Information : -
Odometer : 47449.5 mi
Motorcycle Date : 06-04-2019
Distance to next service : 5738.6 mi
Service due date : 24-04-2023
XFSA : -
Controller Type : Satellite Body Controller
Controller Name : XFSA
Controller : 0x0F8000
Serial Number : 1300996337
Manufacturer : Loewe / Lear
Manufacture Date (YY/MM/DD) : 13/02/09
VIN : ZZ24409
Program Count : 3
Program Count Maximum : 1024
Firmware Date (YY/MM/DD) : 15/06/12
Kilometers when programmed : 0.00
Number of FW configurations : 4
HW Electronics (HWEL) :
Firmware ID : 0x08B0
Firmware Version : 002.005.001
Bootloader (BTLD) :
Firmware ID : 0x0894
Firmware Version : 004.001.000
SW Memory Image (SWFL) :
Firmware ID : 0x0895
Firmware Version : 006.006.002
Coding Data (CAFD) :
Firmware ID : 0x0896
Firmware Version : 006.025.002
Fault Codes : 2
Fault Code Value : 0x803E8B
Fault Code Meaning : Front seat heating (rider), open circuit
Frequency count : 1
Logistic (Healing) count : 18
Record number : 1
Odometer : 44860.1 mi
Absolute Time : 2954
System voltage : 14.00 V
Ignition status : ON
Fault Code Value : 0xCC943A
Fault Code Meaning : No CAN message (from GM)
Frequency count : 1
Logistic (Healing) count : 0
Record number : 1
Odometer : 47146.9 mi
Absolute Time : 7095978
System voltage : 12.50 V
XBMSX : -
Controller Type : Engine Controller
Controller Name : XBMSX
Controller : 0x0F8B00
Serial Number : 0170033808
Manufacture Date (YY/MM/DD) : 13/01/16
Program Count : 2
Program Count Maximum : 60
Factory I-Level : K001-12-08-510
Actual I-Level : K001-15-03-511
Backup I-Level : K001-14-02-500
Battery voltage : 12.50 V
VIN : WB1061206DZZ24409
Model : K 1600 GTL (K48)
Operating hours : 1089h 34m 27s
Number of FW configurations : 5
Firmware ID : 0x08A3
Firmware Version : 004.000.000
Bootloader (BTLD) :
Firmware ID : 0x0C49
Firmware ID : 0x0CBD
Firmware Version : 008.000.001
Firmware ID : 0x0D2F
Firmware Version : 008.020.000
Firmware ID : 0x08A2
Firmware Version : 000.008.007
Fault Codes : 1
Frequency count : 1
Record number : 1
Engine RPM : 0 rpm
Speed : 1.4 mph
Vehicle Order :
Date : 0812
Series : K048
Type : 0612
Paint : 0NB2
Upholstery : 0000
Extras :
134 : Adaptive Headlights
138 : LED additional headlight
143 : Bluetooth interface
182 : DTC
376 : BMW US Radio
416 : ESA
417 : Central locking system
430 : Safety pack
431 : Equipment package 1
530 : Tyre Pressure Control (RDC)
603 : Alarm system
792 : Seat bench, high
XRDC : -
Controller Type : Tyre Pressure Monitor
Controller Name : XRDC
Controller : 0x0F8100
Serial Number : 0391301531
Manufacturer : Schrader
Manufacture Date (YY/MM/DD) : 13/02/08
VIN : ZZ24409
Program Count : 1
Firmware Date (YY/MM/DD) : 14/02/27
Firmware ID : 0x0B49
Firmware Version : 000.001.008
Bootloader (BTLD) :
Firmware ID : 0x0CB1
Firmware Version : 000.002.025
Firmware ID : 0x0CB2
Firmware Version : 001.000.070
Firmware ID : 0x0B4B
Firmware Version : 000.005.000
Fault Codes : 1
Fault Code Value : 0x481F84
Fault Code Meaning : Voltage supply (undervoltage)
Frequency count : 2
Record number : 1
Odometer : 25147.4 mi
Absolute Time : 214748364
Record number : 2
XASW : -
Controller Type : Active Headlight
Controller Name : XASW
Controller : 0x0F8200
Serial Number : 1301100258
Manufacture Date (YY/MM/DD) : 13/01/11
VIN : ZZ24409
Program Count : 1
Firmware ID : 0x089E
Firmware Version : 000.003.000
Bootloader (BTLD) :
Firmware ID : 0x089B
Firmware Version : 001.002.000
Firmware ID : 0x089C
Firmware Version : 001.004.000
Firmware ID : 0x089D
Firmware Version : 001.000.004
Fault Codes : 0
No Faults found :
XABS : -
Controller Type : ABS Brakes
Controller Name : XABS
Controller : 0x0F8300
Serial Number : 6003500435
Manufacturer : Continental Automotive
Manufacture Date (YY/MM/DD) : 13/01/25
VIN : ZZ24409
Program Count : 0
Program Count Maximum : 1000
Firmware Date (YY/MM/DD) : 13/01/25
Number of FW configurations : 3
Firmware ID : 0x08BC
Firmware Version : 001.000.000
Bootloader (BTLD) :
Firmware ID : 0x08BA
Firmware Version : 001.001.000
Firmware ID : 0x08BB
Firmware Version : 002.001.000
Fault Codes : 0
No Faults found :
XESA : -
Controller Type : Electronic Suspension
Controller Name : XESA
Controller : 0x0F8400
Manufacture Date (YY/MM/DD) : 13/02/03
VIN : ZZ24409
Program Count : 0
Firmware Date (YY/MM/DD) : 13/02/03
Firmware ID : 0x08AC
Bootloader (BTLD) :
Firmware ID : 0x0897
Firmware ID : 0x0898
Firmware ID : 0x089A
: Hall Sensor Installed, Rear Strut
Fault Codes : 2
Fault Code Value : 0x480DC5
Frequency count : 2
Record number : 1
Time : 37
Speed : 0.0 mph
Engine RPM : 0 rpm
Record number : 2
Time : 0
Speed : 40723.4 mph
Engine RPM : 0 rpm
Fault Code Value : 0xD7143A
Fault Code Meaning : No CAN message (ambient conditions from DME)
Frequency count : 2
Record number : 1
Time : 352505
Speed : 0.0 mph
Engine RPM : 0 rpm
Record number : 2
Time : 7095978
Speed : 0.0 mph
Engine RPM : 0 rpm
XDWA : -
Controller Type : Anti-Theft Alarm
Controller Name : XDWA
Controller : 0x0F8700
Manufacturer : META System S.P.A.
Manufacture Date (YY/MM/DD) : 13/01/09
VIN : ZZ24409
Program Count : 2
Firmware ID : 0x0A4C
Bootloader (BTLD) :
Firmware ID : 0x0A49
Firmware ID : 0x0A4A
Firmware Version : 001.006.003
Firmware ID : 0x0A4B
Firmware Version : 001.005.005
Fault Codes : 1
Fault Code Value : 0x800029
Fault Code Meaning : Alarm activation
Frequency count : 4
Record number : 1
Odometer : 27257.1 mi
Record number : 2
Odometer : 40231.3 mi
XKOMBI : -
Controller Type : Instrument Cluster
Controller Name : XKOMBI
Controller : 0x0F8800
Serial Number : 0000024678
Manufacturer : Preh GmbH
Manufacture Date (YY/MM/DD) : 13/02/15
Program Count : 2
VIN : ZZ24409
Number of FW configurations : 6
Firmware ID : 0x08A7
Bootloader (BTLD) :
Firmware ID : 0x0C4D
Firmware ID : 0x0CBC
Firmware Version : 001.008.000
Firmware ID : 0x0CBB
Firmware Version : 000.003.002
Firmware ID : 0x08A6
Firmware Version : 001.006.022
Hardware Type (HWAP) :
Firmware ID : 0x08A9
Firmware Version : 255.255.255
Fault Codes : 1
Fault Code Value : 0xE1143A
Fault Code Meaning : CAN message missing (from the Ground Module (GM))
Frequency count : 1
Logistic (Healing) count : 4
Record number : 1
Absolute Time : 7095979
Battery voltage : 12.30 V
Engine RPM : 0 rpm
Speed : 0.0 mph
Vehicle Order :
Date : 0812
Series : K048
Type : 0612
Paint : 0NB2
Upholstery : 0000
Extras :
182 : DTC
376 : BMW US Radio
416 : ESA
430 : Safety pack
603 : Alarm system
XAUDIO : -
Controller Type : Audio Controller
Controller Name : XAUDIO
Controller : 0x0F8900
Serial Number : 8003326011
VIN : ZZ24409
Program Count : 0
Firmware Date (YY/MM/DD) : 99/99/99
Firmware ID : 0x0EF4
Bootloader (BTLD) :
Firmware ID : 0x0FDE
Firmware Version : 001.000.002
Firmware ID : 0x0A47
Firmware ID : 0x0CBA
Firmware ID : 0x0A48
Firmware Version : 000.005.001
Fault Codes : 5
Fault Code Value : 0xB7F800
Fault Code Meaning : Amplifier output to left speaker, open circuit
Frequency count : 1
Record number : 1
Odometer : 32137.6 mi
Fault Code Value : 0xE1D422
Fault Code Meaning : No CAN message (vehicle speed from ABS)
Frequency count : 1
Record number : 1
Fault Code Value : 0xB7F801
Fault Code Meaning : Amplifier output to right speaker, open circuit
Frequency count : 1
Record number : 1
Fault Code Value : 0xB7F818
Fault Code Meaning : Sirius antenna, open circuit
Frequency count : 5
Record number : 1
Odometer : 27334.8 mi
Record number : 2
Odometer : 32148.8 mi
Fault Code Value : 0xB7F819
Fault Code Meaning : Sirius antenna, short circuit
Frequency count : 7
Record number : 1
Odometer : 27024.1 mi
Record number : 2
Odometer : 46476.4 mi
XBCO : -
Controller Type : Body Controller
Controller Name : XBCO
Controller : 0x0F8A00
Serial Number : 1302900904
Manufacture Date (YY/MM/DD) : 13/01/29
VIN : ZZ24409
Program Count : 1
Firmware ID : 0x08AF
Firmware Version : 001.006.001
Bootloader (BTLD) :
Firmware ID : 0x0891
Firmware Version : 004.000.003
Firmware ID : 0x0892
Firmware ID : 0x0893
Firmware Version : 006.050.017
Fault Codes : 3
Fault Code Value : 0xE59420
Fault Code Meaning : No CAN message (status left multifunction switch from the KOMBI)
Frequency count : 1
Record number : 1
Odometer : 27275.1 mi
Absolute Time : 16777215
System voltage : 13.00 V
Fault Code Value : 0xE59426
Fault Code Meaning : No CAN message (from KOMBI)
Frequency count : 1
Record number : 1
Fault Code Value : 0xE5941C
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
Engine RPM : 0 rpm
Speed : 1.4 mph
AutoScan : -
XFSA : -
VIN : ZZ24409
Program Count : 3
Bootloader (BTLD) :
Fault Codes : 2
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
XBMSX : -
Program Count : 2
Bootloader (BTLD) :
Fault Codes : 1
Frequency count : 1
Record number : 1
Engine RPM : 0 rpm
Speed : 1.4 mph
Vehicle Order :
Date : 0812
Series : K048
Type : 0612
Paint : 0NB2
Upholstery : 0000
Extras :
182 : DTC
376 : BMW US Radio
416 : ESA
430 : Safety pack
603 : Alarm system
XRDC : -
VIN : ZZ24409
Program Count : 1
Bootloader (BTLD) :
Fault Codes : 1
Frequency count : 2
Record number : 1
Record number : 2
XASW : -
VIN : ZZ24409
Program Count : 1
Bootloader (BTLD) :
Fault Codes : 0
No Faults found :
XABS : -
VIN : ZZ24409
Program Count : 0
Bootloader (BTLD) :
Fault Codes : 0
No Faults found :
XESA : -
VIN : ZZ24409
Program Count : 0
Bootloader (BTLD) :
Fault Codes : 2
Frequency count : 2
Record number : 1
Time : 37
Speed : 0.0 mph
Engine RPM : 0 rpm
Record number : 2
Time : 0
Speed : 40723.4 mph
Engine RPM : 0 rpm
Frequency count : 2
Record number : 1
Time : 352505
Speed : 0.0 mph
Engine RPM : 0 rpm
Record number : 2
Time : 7095978
Speed : 0.0 mph
Engine RPM : 0 rpm
XDWA : -
VIN : ZZ24409
Program Count : 2
Bootloader (BTLD) :
Fault Codes : 1
Frequency count : 4
Record number : 1
Record number : 2
XKOMBI : -
Program Count : 2
VIN : ZZ24409
Bootloader (BTLD) :
Fault Codes : 1
Frequency count : 1
Record number : 1
Engine RPM : 0 rpm
Speed : 0.0 mph
Vehicle Order :
Date : 0812
Series : K048
Type : 0612
Paint : 0NB2
Upholstery : 0000
Extras :
182 : DTC
376 : BMW US Radio
416 : ESA
430 : Safety pack
603 : Alarm system
XAUDIO : -
VIN : ZZ24409
Program Count : 0
Bootloader (BTLD) :
Fault Codes : 5
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
Frequency count : 5
Record number : 1
Record number : 2
Frequency count : 7
Record number : 1
Record number : 2
XBCO : -
VIN : ZZ24409
Program Count : 1
Bootloader (BTLD) :
Fault Codes : 3
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
Frequency count : 1
Record number : 1
