1 - 6 of 6 Posts
I don't think the bulbs are fused beyond the CAN BUS reporting there is a bulb failure, when mine went it was a unit replacement
Reactions: AndyspK16
Agree with mole, unit replacement, I had it under warranty on my 2016, water went in and it stopped working.
Thanks guys found the issue on/off button pressed this 3/4 times and now both are working .. Cheers stay safe
I suspect it will fail again, probably resistance inside the unit, if under warranty then get it into the dealer booked early to save the time allotted, it will be stored in the fault memory. If it goes again and you haven't photographed it already, then capture it as proof
1 - 6 of 6 Posts
