I am not abusive with the bike 91 octane is what we have here in California I will be fine I talk to Bren. Stage one won’t make it for me Anymore off the bottom it’s too soft
It's not about abusive. This is from Bren in a recent post:
"91 octane fuel is not all the same. What we see in MA, midwest, PACNW, Canada, does not equal what you see in CA, AZ, NV. ACN91, as they call it (arizona, california, nevada 91), fuel is easily the worst in the country. Couple that with high ambient temps and the bikes are more prone to knock in both stock or tuned configuration"
"If you get stuck on the stage 2 map with only 91 octane or less around, it's not the end of the world, the ECU will learn out most knock correction by reducing ignition timing. The Bosch ECU's are very smart and can learn knock quickly, turning down ignition timing to avoid issue. Would I rely on this method long term? No"
Do what you want, but I'd think hard about leaving the Stage 2 map on your bike here in California.
