1 - 16 of 16 Posts
Does anyone know the Color Code for the 2016 BMW K1600 & Where I can get some Touch Up Paint?? Dealer say the code is N0P. Called and E-mailed several Touch Up paint Company's (ColorRite, TouchUp Direct, etc.) & they say this is an invalid code. Maybe NoP means "No Paint"?? Best,
Doc::confused::mad::confused:
I'm sure its marked on the back of the panels, but have a go with this > ColorRite Motorcycle Paint
Color Code 2016 BMW K1600 GTLE
It appears that the color code for the 2016 BMW K1600 GTLE is N0P. None of the links/ vendors provided so far stock this touch up paint color code. If anyone has recieved this touch up paint from a vendor for the 2016 BMW K1600 GTLE please let me know. Best,
Doc:gm:gm
Doc:gm:gm
If you look at the body panels for the model on the micro fiche you get their colour markings > K48 (K 1600 GT, K 1600 GTL) K 1600 GTL Excl. (0603, 0613) Painted parts WND1 mineral-weiss met. > this is a UK site,
The Motrrad site lists GTLE
  • Ocean Blue Metallic Matt
  • Glacier Silver metallic
  • Black Storm Metallic
GTLExclusive
  • Sparkling Storm Metallic
They can't keep inventing new colours
NoP is Not Our Problem
Doc:gm:gm
I just checked the Parts Fiche on Max's website and it hasn't been updated for the '16 GTLE. Once it is, the paint code will be listed in the "Painted Parts" item within the "Vehicle Trim" category. I know it's not helpful to you, but looking at the Fiche identifies the paint mixture code for the '14/'15 GTLE as A96 - Mineral White Metallic.
I know the sticker on the back of the panels lists the paint color, I don't remember if it has the actual paint code listed also. May be worth pulling a panel or two off to see (if you haven't done so already). NoP just doesn't seem right...
go to BMW VIN Decoder or here and put in the last 7 of your VIN. It will give you the build sheet for your bike, including your paint code. For instance, my Sakhir Orange GT Sport is NC6.
I would also try DR Colorchip.
So here's a dumb question -- is Sakhir Orange on a bike the same as Sakhir Orange on a car? Amazon touch-up
(Apologies for raising this thread from the dead... but I figure it's better than starting a new one)
If the mfr paint code is the same (B50 in this case), and especially if the automotive applications are roughly the same yr range, then they are likely the exact same color formula. BMW is not the only mfr to do this. Honda has color codes that have both automotive and motorcycle applications.
Anyhow, I've been toying around with the idea of painting my Givi E55 top case Sakhir Orange to match the bike, so I did some digging around. Evidently, BMW has no less than 3 orange paint code a few yrs ago: Fire, Valencia and Sakhir. I think Sakhir is the most gorgeous, especially on a car.
Having an automotive application really helps. It means I can get the base color from any of the local automotive refinish job shops, instead getting pounded in the rear end by Colorrite. I always end up getting more than I need, since the price for a quart is typically not a whole lot more than for a pint, and the paint shop usually does a better (more accurate) job of mixing the various ingredient colors that make up the paint formula. Not surprising since the larger the quantity in one batch, the less influence a bit more of less of any one ingredient color has on the final shade. I might see what other bits and pieces I can shoot with it while I'm at it. :cool:
I m in the same dilemma. I did wrote to BMW and ask if B50 and NC6 were the same and they re direct me to my dealer. Once at the dealer, they told me that BMW dont authorize motorrad to sell touch up paint as the automobile dealers are the only ones to sell them.
I would think it s the same color but who am I to confirm it
It will cost me 20$ to know since I ordered a bottle of b50 at Amazon
Will see
I only see NC6 referenced in Corlorrite's own website. All other references, including BMW's own labels and docs, use B50. I highly doubt BMW would purposely confuse themselves by using the same B50 code on both automotive and motorcycle application and for them to refer to different formulas.
Just bear in mind though, that even if it is the correct formula, each batched of mixed paint will quite possibly be slightly different. Besides mixing ratio errors, the OEM paint could have faded somewhat and changed hue or saturation. This sometimes presents a problem in automotive refinishing, where a spot repair requires the painter to "blend" into existing painted panel. It's customary for the painter to bring in an existing body panel, say the fuel door, to the job shop for verification and "tinting" to match, if necessary. However, painting motorcycle panels are just about always an overall job. The parts are small enough that it's easier to repaint the whole thing. So precise color match is less of a problem.
If you are buying touch up paint for small rock chips, it won't matter.
Thank you for this thread.
1 - 16 of 16 Posts
