You mean 10W-40?After 3 oil analysis I now change at 3500 miles and only use AMSOil Metric 5w40.
Don't thinks so; I have many many more important things to worry about like the expiration date of my beer, the world running out of petroleum, and global warming. :grin:No.....but you better!
Mostly placebo effect ... modern engine, modern oil, if engine parts are going to fail, all the oil changes in the world won't make ANY difference. :grin:Agreed, oil change every 3K mikes or a year is very beneficial for your engine parts.
Not necessarily, e.g. I do oil changes at 3500 miles based on the results and recommendations from 3 oil sample analysis done at 6K, 4.5K and 3K. Granted it may be overkill, but after loosing a motor (excessive oil usage) at 49K miles I'm gun shy.Mostly placebo effect ... modern engine, modern oil, if engine is going to fail all the oil changes in the world won't make ANY difference. :grin:
Tom
If you had sacrificed a chicken yearly and every 3500 miles it would have lasted at least 52.5K - 55.7K miles. :crying:Not necessarily, e.g.Granted it may be overkill, but after loosing a motor (excessive oil usage) at 49K miles I'm gun shy.
I apologize for entering/ continuing this discussion, neither of us will change and I've already stated my position :wink::@TPadden, I'm not blaming anyone. Oil samples taken >3500 miles showed excessive oil break down and contamination.
..that said I'm all for you doing whatever makes you feel good!
Tom
Nothing says 'a company recognizing its audience' like that statement. Something tells me this is more about the engineering/technology in the engine than it is about riders habits but whatever, unless those bars are a block apart and that says more about the consumer than it does the bike.Short trips when the engine does not fully reach operating temperature do more harm than long trips to the oil. Sufficient time at higher temperatures will help evaporate all moisture from the oil.
I even recall reading in a HD owner's manual that if you do short trips (like many bar hopping HD owners do) oil should be changed every 1500 miles, not the 5,000 miles in the normal schedule.
I would be more concerned with 3,000 miles of short trips over a year than 6,000 miles of highway over a one month period.
But synthetic oils hold their properties much better (and longer) than dino oil...
