1 - 20 of 20 Posts
When winter finally relented enough to do some riding, I noticed that the Nightowl was a bitch to start and would occasionally turn on the check engine light. Still, with repeated pressing of the starter switch, the bike eventually would start and run, but not very well. I sounded like it was missing (at least one cylinder not firing) a lot, even on idle but the behavior was not consistent.
I chalked it up to the near full tank of gas (albeit treated) sitting in the tank over the long winter and gumming things up. On a ride to get the parts moving before an 18k service (38k total) the missing problem continued but remained inconsistent. I got it back to the garage and started the 18k service.
During the 18k service, I drained the gas and pulled the fuel pump/sender module out of the tank because I needed to fix a problem with a flakey fuel gauge that would go empty for a moment and reset to the original level (thread on that subject here). During the fuel sender refurb, I didn't notice any gummy residue at the bottom of the tank or on the fuel pump strainer. I reasoned that the gas was just skunky and the problem would go away when I put a full tank of fresh gas in the tank.
Then the plot thickened. My pre-18k service GS911 auto scan showed the following harbinger of doom:
Code:
21F5E2 : Fuse activated for Electric fuel pump, overload
Currently present : NO
Engine warning light (MIL) : NO
Frequency count : 5
Logistic(Healing) count : 40
..Fault Code History :
....Record number : 1
....Odometer : 38546.7 mls
....ABS time : 7049529
....Electric fuel pump voltage : 1.95 V
....Engine speed : 255.0 rpm
....Battery voltage : 10.22 V
....Time since engine start : 0.00
....Record number : 2
....ABS time : 7049594
....Electric fuel pump voltage : 1.93 V
....Engine speed : 159.5 rpm
....Record number : 3
....ABS time : 7052623
....Electric fuel pump voltage : 1.96 V
....Engine speed : 988.0 rpm
....Battery voltage : 11.47 V
....Time since engine start : 0.10
This led me to believe that the hard starting was probably due to the fuel pump sticking at startup and drawing too much current. All the recorded errors were right in a row (time-wise) and all were before the engine was running. I figured (hoped) that fresh gas and more riding would free up the pump and solve the problem.
Nope.
I just finished my first day's ride down to the Fontana Getaway (a week early, but I'm attending a conference this week on the way) and the bike, even after a fresh tank of premium gas, continues to run like crap. Here's the pattern of behavior that I noticed during ~300 miles of riding:
  • It starts really hard cold and starts a little easier warm, but still requires multiple start attempts to get running.
  • It will miss a bit on idle with the miss persisting for 10-15 seconds before going away. The interval is not constant and is exacerbated by high electrical loads like heated grips/seat/clothing.
  • In casual riding, the engine runs OK, but you can feel when it starts missing. The length of the missing varies.
  • It will cruise at highway speeds OK, but the miss still comes and goes.
  • When the tank was down it its last gallon or two, the miss condition got much worse.
  • When you attempt more spirited riding, leaning on the throttle almost always brings the miss condition. If you lean on the throttle for too long or open it roo abrubtly, the engine dies until you close the throttle and open it again. Even babying it during passes on a two-lane road was a serious challenge. Accelerating up hills? Forget about it. It's worth noting that I never experienced a backfire when the engine resumed after these temporary "die" conditions.
OK, so I'm thinking fuel starvation. Perhaps the pump is running, but not at full pressure. Perhaps the pump only runs in start/stop cycles. If it were a coil, I would expect the unburned gas to backfire in the exhaust when the engine came back to life after temporarily dying on hard acceleration. I happen to have my laptop with me (for the aforementioned conference) and I pulled up the fuel pressure test procedure in RSD, which indicates a desired fuel pressure of 3.5 bar +/- 0.5 bar, so anywhere between 3-4 bar. When I had the GS911 monitoring the bike in my garage after the 18k service, I think I remember seeing a reported fuel pressure of 12-15 psi, which is nowhere near the expected 43-58psi (converted from 3-4 bar). Having said that, the fuel pressure test procedure uses an actual pressure gauge as opposed to reading the output of the pressure sensor on the bike; perhaps the on-board fuel pressure sensor isn't very accurate(?).
So I guess I need a fuel pump... and tomorrow is Sunday... Easter Sunday... so nothing will be open.
Wonderful.
Tomorrow morning I'll hook up the GS911 before the day's ride and get a firm reading on the fuel pressure from the on-bike sensor. After today, I'm fairly confident that I can coax it another 300 miles to Charlottesville, VA for the conference.
So, how to fix this? It appears that I have two options:
#1 - The closest BMW dealer is down in Roanoke, VA so I can't get work done for the four days I'm in Charlottesville. Also, it doesn't look like BMW sells the fuel pump by itself, just the entire flange and fixture (but without the fuel sender; that would have to be transplanted). Assuming that the dealer has the part in stock, it's not a very complex job to switch it (I could do it in the parking lot if they didn't have time, assuming a near-empty tank). Even if they don't have it in stock, they may be able to get it by Friday. There are also dealers in Ashville, NC and Knoxville, TN, both (sorta) on the way to Fontana.
#2 - According to the EME site for the K1600 fuel system, there are compatible pumps from EnDuraLast and Bosch that I could, conceivably, two-day ship to my hotel (probably along with a new strainer and rubber mount bushings) and swap it out one evening during the conference. A search around the forum found at least one other forum member who replaced their fuel pump via this method.
I'm going to try option #2, hoping that EME (or some other supplier) has the required pump in stock and can get it to me in time. That would be the most direct, and coincidentally least expensive, solution.
The good news is that the refurbished fuel level sender didn't flake out at all today. I took some photos of that refurb effort and will post a link to that story when I get a chance.
Questions:
  • Based on the behavior and observations, does anybody have other possible culprits that I need to check?
  • Anybody in Charlottesville, VA (or nearby) that wants to help me with the swap? I have the tools to get to and remove the fuel pump, but the Bosch pump apparently needs to have a standoff boss cut off before installation; I don't pack a Dremel tool on trips.
  • Can somebody with a healthy bike hook up their GS911 and get a reading on the fuel pressure from the engine module? I'd like to see if a healthy bike reads significantly higher that what I'm seeing.
Alas, life is an adventure.
Ghost
Sounds like you have the essence of the problem; sorry I can't help with fuel pressure readings, but the usual clue is just to listen in to the fuel main charging up when you switch on. If it runs on incessantly, or fails to even commence, then you have confirmation.
However, after a winter lay-up I would always want to consider battery condition too. Higher than normal voltage drops at start-up can create issues with any modern bike, especially those with canbus systems.
I brought one of these pumps from ebay > https://www.ebay.co.uk/itm/FOR-BMW-...068659?hash=item4d7415d133:g:-q8AAOSwgQ9Vwhw0.
Things to note
The diameter of the supplied pump was slightly bigger than the original. I split the length of the holder with a junior hack saw and then used cable ties to tighten in place
The rubber seal has to be installed in the tank before refitting, mine pulled through as i removed the pump, and caused protracted thinking before i realised what was causoing a problem reinstalling
The strainer is a bugger to remove, it is a push fit but no information in the supplied kit and the retaining circlip
The GS911wifi showed no bad codes? If your bike threw an engine light there should be a trouble code...
The only related code is:
The other unreleated/historical/fixed codes from the pre-service reading were:
B7F819 : Sirius aerial, short circuit
I get these from time to time. This one was historical. The Sat radio works fine anyway.
80401D : Tank switch error
This was a historical code related to the keyless opening of gas cap, usually due to me opening the latch too quickly.
800E83 : Horn, open circuit
I have an aftermarket horn wired through a PDM60. The only load on the original horn circuit a trigger circuit into the PDM60, which draws only a tiny amount of current. Consequently, this one is expected every time I use the horn.
800EA9 : Fuel level sensor, open circuit or short circuit to battery positive
This is the flakey fuel sender problem, which I fixed during the recent 18k service (write-up to follow when I get the time).
I'll do another read this morning before I start my ride and will report on those too. Need to eat breakfast first.
Ghost
If the starter wasn't spinning strongly, I'd definitely consider the battery as an option. The problem persists during the running condition, with good voltage even with all the lights on and electrics (grips/seat/clothing) all running. I don't think the battery is the culprit.
Ghost
I did a fresh scan and monitor this morning with the GS911. We now have additional evidence that the fuel pump is toast.
I hooked up the GS911, and attempted to start the bike. It catches momentarily and dies, lighting the check engine light. I attempt to start it again and this time it runs with the check engine light still lit.
I do a scan and the only code is the oh-to-familiar:
This time I notice that the MIL light for this code is ON and the coded condition is currently active.
I do a live monitor of the engine controller and noted two interesting pieces of information:
Fuel pressure: 12.85 PSI
Fuel pump: OFF
That fuel pressure is below normal atmospheric pressure (14.7 PSI), which makes sense if the fuel pump is dead since the fuel rail only sees the weight of the gas in the tank above it and the injectors are subtracting from that when they’re open. It also follows that the problem gets worse as the tank gets closer to empty and there’s less pressure exerted by the fuel in the tank.
I shut off the bike, cycled the ignition, and restarted it. This time there’s no check engine light. The fuel pump shows as ON but the pressure is still below 13 PSI.
Conclusion? The bike can run with a dead fuel pump, just not very well and only if you have at least a couple of gallons in the tank (the more the better). I’ll proceed to requisition a replacement fuel pump and try to swap it out in Charlottesville, VA this week.
If you live in/near Charlottesville and want to help out, let me know. I could use some help siphoning and storing the gas in the tank during the swap and the replacement pump needs a small boss cut off before installation (I don’t pack a Dremel on trips).
Ghost
Can't help you.
But I think I have a fuel pump issue as well. I seem to only have this problem on starting or idling. It'll just die in traffic, then re-start with this issue. Can usually shut down and re-start and it runs fine for a while. On the highway it runs like a top. Was in the shop and they thought it was a "throttle valve." Fixed that and still having the same problem. Now they're talking about the fuel pump. We'll see.
I've only had the bike since December (albeit almost 8000 miles), but in the shop about once a month is starting to confirm my worst fears about BMW. Hopefully they get this sorted out.
...and hopefully OP will get his issue sorted as well.
open the fuel filer and listen for air intake when stopped, can be a trapped vent
It would be useful to see what the return volume is just as a means to verify an issue with the pump. Although being on the road that's probably not possible.
Good luck with the fix.
There’s no gasp of intake air when I open the tank to fill it. Also, I checked the vent when I had the Tupperware off the tank. The vent is fine.
Discussion Starter #12
If, by "return volume", you mean the volume of fuel that passes through the injector rail and returns to the gas tank, that volume would be zero. :smile: On the K1600s, the fuel pump pressurizes the fuel rail which hosts the six fuel injectors and a single fuel pressure sensor. There is no return line to the tank. Technically, there is a return volume, but it is at a pressure release circuit within the fuel pump itself, which ejects excess pressure right back into the tank. So, yes, hard to measure without removing it.
If you meant just measure the output of the pump, then that's relatively easy. Pull the covers off the tank, disconnect the fuel line to the fuel rail and turn on the ignition. That should send a healthy spray of fuel all over the place. With a 1" diameter piece of rubber or silicone tubing and a bucket, you could catch most of it and gauge pump effectiveness based on that. While this test could provide a slam-dunk indication of a bad pump, I think the preponderance of evidence I have already is pretty solid.
Ghost
Discussion Starter #13
Quick Update
I made it the last 287 miles to Charlottesville, VA. No big changes in bike behavior. It still runs like crap with all the indications of fuel starvation.
Nice scenery over the Appalachian Mountains in West Virgina and Virgina, and much warmer than it was back in Michigan yesterday.
Ghost
I had the exact same problem, same symptoms in 2015, the fuel pump was frozen. I "freed it up" by removing the pump and connecting 12 volts directly to the pump. The pump started working again so I reinstalled the pump and cleared the ECM code. The "jump start" corrected the frozen pump problem until this spring, when it happened again. I am guilty of letting the bike sit for 3 months without fuel stabilizer. But in my defense, this problem never happened to my R1100RT over 10 years of winters. I think the pump or protection circuitry in the K1600 has a design flaw.
Discussion Starter #15 (Edited)
Problem Solved (twice)
Back on Monday morning, I placed an order with Euro MotoElectrics for a replacement fuel pump. Norm at EME did a good job of guiding me to a replacement fuel strainer that included the plastic interface between the fuel pump and the strainer. This is important because it can be an involved challenge to remove the old fuel strainer without destroying it or the plastic interface. I also remembered that the fuel line used a crimp-on clamp at the fuel pump. I didn’t have a crimp tool with me, so I so I grabbed the correct-sized screw clamp as well. Norm at EME arranged for the parts to ship to me at my hotel in Charlottesville via two-day USPS Priority Mail. This would give me two evenings (Wednesday and Thursday) to make the swap.
The question was where to do the swap? I had all the tools but I didn’t have a vessel to store the gas during the swap or a siphon to drain the gas. I also didn’t have a dremel tool to remove the fuel hose clamp.
Here’s where the MOA “Anonymous” book comes to the rescue.
There were four phone numbers for Charlottesville that included the desired codes for “work space” and “work tools” for motorcycle repair. I called all four and within 30 minutes one of them called me back. This gentleman wanted to help and mentioned that we were on speakerphone with his wife listening in. She immediately introduced herself and went into full-on “Mom” mode and asked if I had a place to stay and whether I had eaten dinner it yet. After a very nice conversation, we arranged for me to drop by their place Wednesday evening to do the fuel pump swap. I then went back to enjoying my conference until the parts arrived Wednesday.
Wednesday comes and the parts arrive on time. I pack what I needed for the swap on the bike and take the short ride over the venue for a conference dinner. The bike starts on the first try, mildly surprising, and runs with just a little stumbling on the way to dinner. After dinner, I suit up and head it for the 9-mile ride to the helpful couple’s home for the swap.
The bike runs perfectly.
WTF?
I even tried lugging it uphill in a high gear at low rpms, the kiss of death during the trip down; not a single miss or stumble.
Upon arrival at my doner-garage, I explain the situation, eliciting laughter from my gracious hosts. I decided to swap the pump anyway, reasoning that the old pump was likely under added stress/current/heat for the entire trip down and could fail again at any time. I did a quick GS911 live value test and verified that the measured fuel pressure was now much higher (71 PSI instead of 13 PSI). Then I tore into the bike.
Two hours later, the new fuel pump was in and tested. My total visit time with my rescuers was about 2.5 hours and they kept me company for the entire process. I really lucked out here.
The ride back to my hotel was without incident and much more fun than the ride down from Michigan. The Nightowl finally feels like its old self again.
Thanks to all contributors for their help.
Ghost
Replying to an old post but hoping you can provide some new insight. Bike tries to start but won't....I have a 2013 K1600 GTL showing fault code " 21F5E0..Fuse activated for Electric fuel pump, short circuit to ground or overload" I've read other threads but still not quite sure of the best plan of action. Fuel Pump is only about 1.5 years old, let the stealership replace the original for the same issue. When stationed in MD, had a similar problem and it was just a big gray relay. The dealer replaced it while under warranty. Now years later same problem, on an even newer pump. Starting to wonder if the BMW Bike Dealer pulled a fast one. Please assist with photos, location of appropriate relay, fuel pump DIY info, anything that will help.... thanks
Some folks in the past have had that error come up, cleared it with the GS911, and never had it come back again. You might be able to get the fault to clear by leaving the battery disconnected for a while. This is yet another reason for having (access to) a GS911.
Tried deleting code...didn’t work...any other ideas?
Dàmn. That sucks...
I have not read the entire history of this thread so I am not sure what lead up to this nor what you have tried, but a couple things come to mind...
Maybe start by unplugging the fuel pump then clearing the code and seeing if the same code comes back. If it does, then the problem is not with the pump but with the wires/connectors that power the pump. If it does not come back (most likely you will get a "Fuel Pump Open" kind fault) then the problem is with the pump. Disconnecting the pump is pretty easy, just a bunch of plastic and the air box to get out of the way. There are two connections on the metal plate at the rear of the tank. One is the level sender, one is the pump power.
If the fault does go away with the pump disconnected, and if it has been sitting a while without running, it could be gummed up (even if it has not been sitting, it could be gummed up). Something that can cause a motor to draw too much current is if it is seized. Might be worth an effort to pull it out and soak it in fresh fuel. Maybe rapping it a little with a small hammer to knock it loose...
If the fault does not go away with the pump removed, start tracing the wires back to the ECU and look for a kink, break, or penetrating screw.
1 - 20 of 20 Posts
