1 - 10 of 10 Posts
Wasn't expecting this much oil to come out. Apparently this is from someone over filling it in the past. Looks like my OR floor after a splenectomy.
153406
If you haven't already you should check your air filter. The tray that that tube is attached to is under the air filter.
Reactions: 1004ron
Discussion Starter · #3 ·
That's what I was replacing when I decided to go hunt for the tube. Air filter was clean, but I replaced it anyway.
I spotted the problem right away.......there is an A & W ROOT Beer can in the picture......that should immediately be replaced with a quality Belgian ale, German Weissbeir or Irish stout of your choice!;)
I pulled the "BMW" cover off my '20 GTL. While there were a couple shrouded wires in that area, I didn't find any tubing at all. There was one drain tube a little farther back. No plug in it.
2013 GTL
The gas tank filler cap overflow is the same size tube in the same area, so that might be what you're seeing.
I couldn't find mine at first, and after digging and finding it, nothing came out when I pulled its plug.
When I pulled the complete air box and tank for the Quickshifter install, and I laid the air box on its side on the floor a lot of dirty water ran out, so obviously the drain had plugged from not being used.
Discussion Starter · #7 ·
Glass bottles don't make good receptacles for waste fluids, and quality beer doesn't come in cans.
Discussion Starter · #8 ·
I had to grab a flashlight and a pair of large forceps (having spare surgical instruments in the tool box is a great idea) to find it and dig it out. Was pretty deep and only identifiable by the cap.
Reactions: Gunnert
I probably need to go digging in her innards, then! As an RN, I may have forceps stashed somewhere. Thanks for the tip!
I found the condensate drain. I reached behind the frame and found it on the far side of the driveshaft. Short little bugger. Barely long enough to reach past the frame so I could catch anything in a cup. I pulled the plug. There was nothing in it. Peace of mind knowing it's been done.
2013 GTL
Or its plugged like mine was.
1 - 10 of 10 Posts
