Front ABS/Speed sensor position
Hello all,
Well I thought I knew what I was doing but while removing the front wheel to perform various tasks, I loosened nd removed the left side threaded axel sleeve. Once I realize I didn’t need to do that,I figured I’d be able to just find info on how to reset it’s position. No luck, it’s not listed in the repair CD or manual I have. Does anyone know the proper gap between the ABS/Speed pick up sensor and it’s indicating ring? The only information I can find is that the left side axel sleeve is set to provide the proper spacing, just no information on what that is supposed to be. Thanks
Hello all,
