21 - 33 of 33 Posts
Discussion Starter #21
got my bike back today
I talked to the tech for a good 1/2 hour... he did test the battery and the battery was good. he tried the heated grips and they got hot (which I knew) without the battery dropping
he checked the connections and they are all good.
he thinks the issue is the heating elements in the seat ( I think he said they are only drawing 1.4 ohms) which is (his opinion) why there is only 7.4 volts going to the seat (again his opinion that the seat heater does not have enough resistance and the ECU thinks the seat heater is hot and cuts the power to the elements) that is why he wanted the wiring diagrams to see what the draw should have been. great service even if they did not fix it..they did not charge me for the time spent on it. gave me the option of having them replace the elements and hoping that fixes it or to take it to the BMW dealer
I understand the thinking, but whether you have the correct solution remains uncertain. It could be the heater element, it could be the ECU/canbus parameters somehow need a reset. Are there any other K16 owners nearby who could help by providing a seat swap?
IIRC the OE heater elements should show a resistance of at least 3 ohms at the full running voltage from the bike. There is no supply via the canbus until the bike is running & the battery full. Did the tech try taking the seat off & providing the heater element with a full 12v from a remote supply?
Don't you guys mean amps instead of ohms?
Discussion Starter #24
No he did not
His logic (which made sense to me) was without the wiring diagram he does not know if the bike sends 12 volts to the heater elements
He also thinks it could need a reset but his gut feeling is that it is the elements
No he did not
The heat to the seat is adjustable. Switchable for rear and wonder wheel for front.
Sent from my SM-G930F using Tapatalk
Discussion Starter #26
correct, but it made no differerence the resistance was the same (front and rear)
I never tried my heated seat but obviously it doesn't work either
I have to go to the city next week for work (cant take my bike), but think I will take the seat and see if the BMW dealer will put it on a used bike and see if it heats up
Good luck; hope they can sort you out.
Just a thought, that points me toward the need to check the canbus/ECU parameters is ......... what is the chance of both seat heaters failing together.
Now I know sh.. happens, indeed it did on my old Merc S Class when some chump at the dealer managed to damage heater elements in both the seat base & back at enormous cost, whilst working on the sun-roof, but in normal use it seems unlikely.
Have to ask - did you ever find a solution? My heated seat, both the front and rear, don't heat up at all. I have noticed, on rare occasions, with the seat level set to full, sometimes accelerating, going from 2nd to 3rd gear, when the revs hit about 4k, I feel the heat. It's off by the time I get to cruising speed in 6th gear....
I may ask a fellow / local K1600 Rider to test my seat on their bike or vice versa, but I'm curious how it worked out for you??
Discussion Starter #29
i ended up having to replace the heating elements (front and back)
seeing as BMW does not sell the heating elements, i replaced them with Sargent Seat elements and it has worked perfectly since then
What you described makes no sense for a seat that is working correctly. These things heat up slowly. You shouldn't feel a burst of heat for a few seconds and then none.
Agreed! Keep in mind, it would be through my riding gear, and my butt wasn't cold - I am only trying to describe it. Honestly, when I am accelerating, I'm paying attention to that and my surroundings more than my seat heat, so I openly admit, I'm a crappy witness to the events, even though I was right there at the time!!
Discussion Starter #33
Thanks! Who did the work for you?
Our local Kawi dealer
The owner is a friend of mine (actually bought the bike from him) and he has a trained BMW tech on staff which works out good as the nearest dealer is about 160 kms away
21 - 33 of 33 Posts
