Is how to a secret?
I can remove your top box in about 3 minutes. However, I can't promise it will go back on.I knew it was only a matter or time and actually surprised that it's just now being done.
Now to make the top box removable. LOL
The short answer is yes. The long answer has to do with the Magnesson Moss Act.I ride a GTL and 140 mph is plenty fast, for me, so I don't have a dog in this fight but doesn't this void the warranty?
I wouldn't think it would apply to this procedure as it's not maintenance but, rather, an alteration -- and a relatively significant one, at that.The short answer is yes. The long answer has to do with the Magnesson Moss Act.
They told me same thing although I have never felt anything bad at high speed (125) on mine. Then they also told me that someone could do what Hothead is doing. It will void warranty and they recommended if I was going to do it the front end needed to be set up tighter with different equipment. Very interesting conversation with them good guy there.I had a great conversation with one of the technicians at Bob's BMW last week about the speed limiter on the B. He said they have done some playing around with the bikes and have seen/witnessed some pretty significant issues with wobble or vibration/instability at high speeds. They were talking about the stance difference between the GT/GTL and the B and said they think the instability could be caused by the bagger stance and how the rear is lower on those bikes. that, coupled with the floor boards and different contour of the bags is what they think causes the issue.
Won't this ECU remapping be reversed when you have the first dealer service and they update the bike's firmware?No secret if you have the knowledge, multiple pieces of expensive equipment and a bike. All you need to do is put bike on dyno, remap ECU and click multiple buttons on a keyboard ?. JK
Seriously tho, it’s mostly remapping the Ecu.
+1... all engineering is tradeoffs and once you start mucking around in the ECU, be prepared to have the engine grenade on you. It may not be intentional but stuff can get missed and the law of unintended consequences rules.My post is just aimed at making sure you guys ask all the right questions to know what you're getting if you're going to spend $1K+ on tunes.
I don’t often run across people who have actually read it...you apparently have, as have I. The language that you are referring to is what the act was originally intended for. People assume there is a case that unless the manufacturer can prove that your modification caused the failure that they have to cover it. I suspect there is a lot of gray area there. But what is not so gray is that most mainstream manufacturers have a lot more attorneys and money to throw at is so as not to set a precedent.I wouldn't think it would apply to this procedure as it's not maintenance but, rather, an alteration -- and a relatively significant one, at that.
I only read it after reading you post because I had no idea what you were talking about! And yeah, it's an incredibly steep uphill battle going up against an entity with very deep pockets.I don’t often run across people who have actually read it...you apparently have, as have I. The language that you are referring to is what the act was originally intended for. People assume there is a case that unless the manufacturer can prove that your modification caused the failure that they have to cover it. I suspect there is a lot of gray area there. But what is not so gray is that most mainstream manufacturers have a lot more attorneys and money to throw at is so as not to set a precedent.
Good response on your past.
