My 2022 GTL has had times when the left lower cubby will not latch shut also. I sprayed silicone around the button and the latch and that usually did the trick. This last time I took off the outer cover and lubed everything up much more than I could have done without taking it apart and so far it seems to be working. Of course its under warranty and if it persists I will see about a warranty action on it. From what I can see it is simply a mechanical connection of a tiny wire that pulls the latch when you press the button, and it appears that it will not latch itself, at times, like the spring is not strong enough. When you pay that much for a new motorcycle it is a bit annoying when something so simple does not work!
