It sounds like whatever tells the bike the clutch is pulled in, isn't.
Was the side stand/kickstand down through this?When I tried to start the bike this morning, it would not start. Battery read 13.25 volts so I knew it wasn't the battery. Everything was tight but it still would not start.
When I stop my motorcycle, I generally leave it in first gear and bring down the kickstand. I've done it this way forever. Just for grins, I put the bike in Neutral and she fired right up. I put her back in first gear with the clutch in and she would not start. I put her in second gear, clutch in, and she would not start. Putting her in N and she fired up. I think I've figured out the problem.
It there a part or switch that might be shorting out that keeps her from starting in gear. even though the clutch is engaged?
I'm not following - don't you mean if the stand is up and the clutch pulled it should start ?Yep, once you said the stand was down and the bike in gear, I knew it was the clutch switch.
The guys above have the part for you
Same. Bike will not run if side stand is down.I'm not following - don't you mean if the stand is up and the clutch pulled it should start ?
My experience has been that it will kill the engine if you have the clutch pulled in gear and you put the stand down, and sure it won't start in gear with the stand down.
Can you go over in detail how to do this? My 2014 will only start if it’s in neutral 98% of the time.About once every year I have struggles starting in 1st gear. Then I pull the microswitch from under the clutch lever housing and spray it with electrical contact cleaner (or MAF cleaner), put it back on and it starts working again... Not as comprehensive as the DYI referred above, but worked for me 3 years in a row...
Clutch switch.Thanks for all of the feedback.
If the kickstand is down, bike in first gear, clutch pulled in, NO START
If the kickstand is UP, bike in first gear, clutch pulled in, NO START
If I then put the bike in NEUTRAL, kickstand up or down, the bike starts.
Clutch switch. Let us know how you get on with the repair.If the kickstand is down, bike in first gear, clutch pulled in, NO START
