My-Route app?
1607 Views 64 Replies 17 Participants Last post by  JohnS1955
Is anybody using it?
Seems like a pretty extensive app.
They are running the promotion now.
Made in Netherland, I think....
MyRoute-app: The #1 all-in-one route tool
1 - 20 of 65 Posts
I use it since getting my 23 K16GT and needed to find something else than Basecamp. I like it. Here are a couple of posts that describe the features and pros and cons. Btw, there might be more posts about MRA, try a search. :)
2022 K1600 GT
Best Route Planning Software
Reactions: 1
I don't have shares and I've nothing to do with them, but trust me. My route app is the way to go.
It's absolutely perfect.
1000 times better than Basecamp and the people behind it are obsessed to get it even more perfect.
Just give it a try.
Reactions: 2
I use “inRoute”. I’m not kidding about this - last night I made a 200 mile route start to finish with 20 waypoint/via points while in the, ahem, “powder room”. Then air dropped it to my “MyTriumph” app and this morning transferred it from my iPad to my Garmin Nav.
  • Helpful
Reactions: 1
Do a search. Try "MRA".
Who is this in reference to?
For the OP. My Route App = MRA. Many people use it and have commented on it.
I'm assuming you created a GPX file for transfer to the Nav. Did your inRoute created route retain all the via points on the Nav? Was anything lost in the transfer?
How is it compared to Furkot? I don't travel enough to warrant paying a monthly fee. I find Furkot with Google Maps provides everything I need to plot a multi-day trip with some pretty complicated and specific site targets. Me hitting them is a different story. Still annoyed that I turned 30 feet too short for the Red Gulch Dinosaur Tracks road in the wee hours of the morning.
I’ve used Basecamp since it first came out and it has always worked well for me. I plan all my routes on my computer then transfer to my GPS or BMW app. I decided to try MyRoute to avoid having to take my computer on trips (in case I wanted to create new routes). I now use Myroute for route building. I like having the multiple maps, including satellite view. I build routes in TomTom and send those to my BMW app, knowing what I build is what will show up on the bike. If I had my choice I would have preferred that the RT TFT would have had Garmin built into it, but I find MyRoute the best way for me to interact with the connected app. I bought the lifetime gold subscription during an early promotion and IMO was very reasonably priced.
Reactions: 2
Unknown. But there was a quantifiable loss in the powder room.
Reactions: 1
Yes, inRoute creates them as GPX files. All the waypoints and via points transfer over fine. inRoute makes them all waypoints, then you can convert the waypoints to via points in inRoute. I cannot confirm yet if they still act as via points on my Garmin Nav (meaning they don't announce). But I can confirm that they all make the transfer successfully.
I have been using it for several years, and they have done a good job of adding new features. You can get a free version, but you really need to pay the $30 a year to make it worthwhile. It is light years easier to use than BaseCamp so the cost is not an issue at all.
@jjscsix Jim, thanks for the input. I’ve been threatening myself to play with inRoute (@Rambler358 recommended) for some time. I’m mostly happy with BC, so I’ve been putting it off. In the big picture, BC is straight forward, powerful and very easy for transferring routes to the Nav/XT.
But I’m curious as a BC backup. I like playing with new stuff, just because. For whatever reason, InRoute is more more interesting to me than MRA. Maybe because it’s Apple based, and I’m in the Apple universe. I’ll pull the trigger and get to it soon.
Reactions: 1
Once you start using inRoute you’ll scratch your head wondering why Basecamp is so difficult. Admittedly, my problem with Basecamp is that I typically only use it once a year. But I’ve been using it for many years. But that does not excuse its difficulty. And I’m far from alone. I see an awful lot of people on forums who feel the same way.
There has been a tremendous amount of study and learning in the area of UX/UI development since the birth of Basecamp. Sadly, it has not benefitted from any of it, as is typical of any legacy software product.
Reactions: 1
Basecamp is complex and simple at the same time. The program has immense advanced capabilities if you want to dig into them. But for everyday routing, is pretty straight forward. You first create an empty route file (BC List). Organization for your BC route library closely follows the structure of File Explorer within Windows or Finder within Mac. Then within a BC List, you create a bunch of waypoints, order them in your desired sequence, and then press a button to calculate a route. Simple, and I don't understand why it creates a brain-block for many. :unsure: Most of the time is spent in research and refinement -- adding/deleting waypoints, determining if a waypoint should be a via point or a no-alert shaping point, looking at different route paths, etc. The kind of stuff you would do in any routing program.
I'm also a big fan/user of Google Maps --it's the gold standard for route information. l usually sketch out a route first using Google or Google My Maps, because it's so easy create a first cut outline. Then I'll research POIs, gas stations, hotels, restaurants, etc. that will become waypoints in an actual BC route. For me, one of the weaknesses of Basecamp is the search function. It's OK, but not near as functional as what Google provides.
I usually do all my Google Maps work on one computer while I have BC up on another, going back-and-forth between the two. Along with the appropriate Butler Motorcycle Maps down on the floor, I'm there. Google is the primary research tool w/Butler, while BC is the implementation. When I'm done. a few quick clicks transfers the finished route to the Nav/XT device. And it's guaranteed to function on the device the way I created it in BC. I can't do this in the powder room, ;) but my philosophy is to do everything needed ahead of time before a major trip. I have my plan A, B and C routes created and ready to go. On my recent trip cross country to the TTD, I had 3 routes coming home: One for an IBA BB1500G, a second for an IBA SS2000, and a third for a straight cannonball run. If routing has to be done on the fly during the trip (it did on this trip), I'll do it on the Nav/XT Trip Planner app, or just create an A to B route using Google Maps on my phone. This approach hasn't failed me yet.
My motivation for using a program like inRoute would be to have more flexibility doing complex routing while on the road. I like the idea of using an easy to carry iPad for route creation while away from home. Again, it's rare for me to have this need, but I like to cover the bases. It's my nature to go overboard. :)
See less See more
Reactions: 1
I started with Mapsource and moved to Basecamp when it was first launched. I used it extensively until the time came to move on, IMHO Basecamp is "One dimensional" in that it plots a route and that is that, for some that will be all they ever need. MRA is much more advanced and some of the additional features are listed below:
1. Routes can be plotted using Tom Tom, Here and Open Street maps. So that covers Tom Tom and Garmin users.
2. You can drop a layer over the map such as Google, I use Tom Tom maps with Here overlay because the Here maps are nicer. I can drop a Michelin layer on my route if I want to check out scenic roads.
3. You can add traffic info to your map.
4. You can compare how Garmin and Tom Tom will plot the route, for example I can see how Garmin will plot my route and add waypoints to ensure any Garmin mates I share the route with will stay on the same road as me,
5. You can drill down to street level to see what the road looks like and again fine tune the route if there are roads you do not like.
6, It supports Shaping and Waypoints.
7. Using Open Street maps you can vary the type of route you want between waypoints e.g. I want a fast road out of town, then between two waypoints I want a twisty section, then I want a fast section etc.
8. It supports GPX 1.2 format for more advanced features for Garmin devices e.g. Waypoint colour and pausing at waypoint e.g. lunch or fuel stop.
9. There is a large library of routes in the library added by subscribers who want to share their routes,
10. You can expand or split your route e.g. someone sends me a route with 60 waypoints, the CA supports 50 waypoints so I can split the route into say a section with 40 waypoints and a section with 20.
11. Its easy to use on your phone and transfer routes to the BMW CA. and there are good video's on YouTube.
etc.
See less See more
  • Haha
Reactions: 2
@DavidMcK David, Most everything useful you reference is part of my Google Maps (GM) route planning in conjunction with BC that I previously described. GM presents maps in different layer views that are sometimes useful. The layer I use most is satellite, that tells me everything I want to know about any road/highway and the surrounding terrain.
I do all my own routing, and pick my own roads/routes between waypoints. I'll usually pick roads that navigation SW may not even consider. And I guarantee my choices are better. (y) If I'm concerned about traffic, it's when I'm leaving/approaching the vast metropolis called Los Angeles. I not only need to know traffic, but what my best alternative is for snaking through the giant rat maze. That's when my static XT routing is turned off, and the Google Maps dynamic routing on my phone turns on -- there isn't a superior alternative for presenting real-time information.
You call Basecamp "One Dimensional", and in many ways it is. But if you've thoroughly done all your pre-trip planning before leaving, that's exactly what you want. Once you start the trip, you want directions displayed and voice prompts for reinforcement. If you need more while you're riding, you didn't do your job upfront.
There is enough good press on MRA to support that it's a great candidate for the CA/TFT environment. It accommodates the needs of both Garmin and Tom Tom users, which can be useful if you need that duel flexibility. But if you're still working with the Nav/XT as your presentation layer, Basecamp is king.
See less See more
Reactions: 1
1 - 20 of 65 Posts
