Navigator IV problem. Can anyone help?
1 reading
5.2K views 19 replies 12 participants last post by  vtx1800n1
I'm wondering if someone in this group can help me with a Navigator problem I'm having. I have a Navigator IV with latest software and map updates. I use latest version of Basecamp on my Macbook Pro. Latest version of US map. When I create my route in Basecamp it looks great - exactly the route I want to ride. I transfer to the Nav and check the preview and it looks good there too. You can't zoom in to see all the details but the shape looks the same as in Basecamp. The problem is when I ride the route. The magenta route line doesn't always follow the road. I know that I'm on the road that I mapped in Basecamp but the magenta line is somewhere off road. My navigation preference in Basecamp is Fastest Route and same in the Nav so they are in sync on that too. Has anyone experienced the same problem? Any suggestions as to what I'm doing wrong?
#2 ·
It may need a little more research on my part but, just from memory, I recall mention that this problem can be caused by accidentally rotating the map slightly using the Map Controls.
Perhaps you could try rotating the map to see if it corrects the situation. If you still have no joy, I can easily have a dig around.
If your GPS has a routing preference (avoid tolls, avoid U-turns, etc) then it could be changing the route for you. I don't know this, but it feels right.
Yes, it definitely will do that and I've seen that problem before but I have the preferences set the same in Basecamp and in the Nav so that's not the problem this time. Thanks for the input though. It's appreciated.
#9 ·
When making the route in Basecamp, the waypoints need to be exactly on the road. If you’re not zoomed in enough and place the waypoint a little off the road, I remember having similar issues on my IV.
I’d zoom in real close on some of these on the original Basecamp route and see if they are in fact on the road.
BtW Basecamp sucks! Later GPSs have shaping rather than via points for intersections that I think solves this issue.
Keeping both GPS and BC on fastest route is also key and you have that covered.
#10 ·
Thanks to everyone for your input and helpful suggestions. The map on the Nav must have got corrupted somehow because re-installing it did the trick and the Nav is better than it's ever been. My route was clear and unambiguous. The zoom level on the map was better so I could easily see that I was on the route. Even the instructions in my headset were more detailed. It was perfect. Now I'll be able to craft my routes in Basecamp with more confidence. I'm a happy navigator :)
Thanks again for the helpful advice.
#13 ·
OP: Glad your issue got resolved.
Google maps works well.
I recently came across this route planner called mappite. Very impressed with how simple it is to use.
It’s now my go-to route planner. With Garmin’s new XT, one can even transfer the route to the unit using the Garmin drive app. No cables required. Can be done on the fly.
Short video here
#14 ·
146038
146039
Is this the most up-to-date BaseCamp and Map version for the NavIV (2013 GTL)? Has anyone purchased the updated maps and is it worth it considering this is 2013 Technology?
Thanks!
Phil
#20 ·
Always make sure your device and Basecamp have the same map version also. You have to select to update both of them in Basecamp.
Reactions: Piper01801
