1 - 20 of 44 Posts
So after reviewing some threads and the tip to 3D printed part on Thingiverse. I decided to re-engineer the solution and came up with this replacement plate.
144530
It is designed to work with this wireless phone mount on Amazon : $50
I Designed it with the free version of Fusion360 for personal use.
I had it printed for a cost of $35 at Voodoo manufacturing; But found out I could probably get for $20 if printed through craftcloud3d.com.
Printed with PETG for strength and UV resistance.
144532
144531
I will update once I post the design files to a free service. you can message me with email address if you want them direct.
Outta This World
Great job but that print quality is really meh, I would definitely find someone else to do the printing. It looks like they printed with a large layer height and the printer itself is not calibrated very well.
Thanks for sharing the STL btw!
I have a design thats been out for years on thingiverse that I used for years without and worked well. PTEG is a good material but if you really like what you going to mount in that area I would use nylon or nylonX as a better choice of material.
Reactions: Lukeinlondon
Outta This World
Posted link in my previous message.
There should be plenty of room for the plate over the wunderlinq. This model is for the NAV VI. The smaller NAV IV version is below.
Also, if there is anything you want on the plate (your name, picture of the queen, etc) its easy to add.
There should be plenty of room for the plate over the wunderlinq. The only thing I don't know is the size of the opening (NAV IV or VI). The plate is easy to modify.
I've got a Nav IV. You original design appears to be for a larger opening? I think mine is 6cm x 10cm.
Outta This World
I think the original STL was for the B. I will measure the opening on my GTL/NAV IV and make a new one.
I measured the NAV IV cover plate size as 65x105mm. That would be the size required to span the opening all the way around. I will shrink those dimension by a bit.
@KHawk
NAV IV Version
Outta This World
@KHawk
NAV IV Version
I have not printed this myself yet, will do so this afternoon.
Discussion Starter #16
Thanks for insight @earthling and @Harryjames . Was curious if the comment about PETG because it may be too brittle and break or that it would look better?
I was under the impression that PETG was fairly strong.
Doh! I am realising the plate doesn't fit the blank space it covers the actual Navs?
Im confused now, the link you shared looks like it covers an actual Nav V/VI and everyone is talking about Nav measurements. Is that how the plate works? I thought the plate covered the blank space up but never wondered how it attaches
Discussion Starter #18
The plate I designed uses 4 small plastic pieces on the corners that go behind the opening and I use #6 wood screws.
Outta This World
Covers the blank opening
1 - 20 of 44 Posts
