Mine still doesn’t read even if I follow the manual word for word.Some folks may be frustrated, but all the parameters in the OM must be met simultaneously.
For example, “for miles and miles” down the road does not work….unless the transmission is in N for at least 10 sec.
…and your dipstick measured oil level, properly checked, is OK? If so, then yours may have a problem.Mine still doesn’t read even if I follow the manual word for word.
Yes, I always use dipstick as the final say but yes oil level is good. Looks like numerous 2022’s are being reported as doing this even when done exactly by the book. Not a huge deal, just more of an annoyance than anything. I like for the stuff I paid for to work right but as long as the dipstick reads correct it’s not a real problem.…and your dipstick measured oil level, properly checked, is OK? If so, then yours may have a problem.
Thanks for the update!UPDATE
I visited the dealer today and was told it could quite possible be a sensor or a software update. He tried to tell me how to do it but left out a few steps...that's okay, that's why we read the manual. Nonetheless, the dipstick works okay and I told him at my next maintenance visit his tech could take a look at it. On a side note, they're only getting 30% of their normal allocation...sad day for sales people.
Checking the oil is important...and easy, especially when flying...I checked it before EVERY flight.
Semper Fi
Of course it can only say OK or LOW, when measured with the engine running, because the oil is circulating, the oil pump generating different pressures depending on the RPMs. Generally, oil level is measured with engine NOT running, to get an exact reading from the oil pan, or oil reservoir on dry sump engines. And since oil expands in volume depending on temperature, for those that measure to the ML, the manufacturers specify operating temp, even though cold temp would be close enough even for the user in Alaska in the depth of winter. This display is just practical for folks who just want to ride, and once a in blue moon during the ride wanna know they're ok because they just remembered they haven't checked the oil since last oil change.Page 40 in the manual
That's if it works, which this thread is all about it not working.Of course it can only say OK or LOW, when measured with the engine running, because the oil is circulating, the oil pump generating different pressures depending on the RPMs. Generally, oil level is measured with engine NOT running, to get an exact reading from the oil pan, or oil reservoir on dry sump engines. And since oil expands in volume depending on temperature, for those that measure to the ML, the manufacturers specify operating temp, even though cold temp would be close enough even for the user in Alaska in the depth of winter. This display is just practical for folks who just want to ride, and once a in blue moon during the ride wanna know they're ok because they just remembered they haven't checked the oil since last oil change.
Ouch! That’s 3/4 of a quart low after the break in service, that’s not a small amount, I would definitely be inquiring with the service department after that!I had glanced at the vehicle screen and noticed the "Check OK" symbol on my '22 B. I didn't give much thought to whether it was a Tuesday or which foot was on the ground. Because apparently there are a lot of rules to follow.
But I was checking the oil level after the break in service. There was zero oil on the dipstick (I do know how to measure it). I added .5 qt. just to see a little oil at the bottom of the stick, and another .25 qt. after that, going thru several warm ups and rest periods each time. I bet the dealer just dumped in some prescribed amount of oil in the block and didn't bother with any devilish detail.
And staying away from it!Ouch! That’s 3/4 of a quart low after the break in service, that’s not a small amount, I would definitely be inquiring with the service department after that!
I didn't say I understood anything the bike is telling me, just knew how to get it to tell me@TouringTim You need to pump up your tyres too![]()
This is so true, I'm going on a long ride next weekend so I will check properly, but in the main it's just a feel good factor.This display is just practical for folks who just want to ride, and once a in blue moon during the ride wanna know they're ok because they just remembered they haven't checked the oil since last oil change.
