Seat heater connection using 2 piece GT seat on GTL?
1 reading
138 views 4 replies 3 participants last post by  campingguy
Greetings all--
I just picked up a two-piece Russell Day Long GT seat to use on my 2015 GTL. I'm lucky that the seat was built for someone about my size!
I'm trying to figure out how the seat heaters connect and know some of you have the answer.
The one-piece GTL seat has one cable and one obvious connection; the two-piece looks to have the cable connect into the rear seat . . . and then there is a smaller connector on the rear seat that matches one on the front.
I'm guessing there's a cable that simply connects the two seats: is this correct?
And, looking at parts diagrams online, I believe I've found cable #61128528423 that may be correct--is it? (#5 in the parts photo)
Photo #1 has the larger connectors circled in green, and the smaller connectors in red.
Thanks!
#3 · (Edited)
It looks like the plug for the front seat is tucked in the crack at the 1:00 position outside the red circle. I can see the wire coming out of the rectangle opening just above the white plastic keeper.
Reactions: C 4
