This is the first I'm hearing about a software update.
I don't have the full details on exactly what it is, but from what they said, it's a major firmware update. Basically they had to hook the bike up and it took about 6 hours to fully download.I too haven't heard of this software update, but if I do, at least I now know to avoid it.
Could you provide more detail on this software update?
What I find odd is that my local dealership hasn't contacted me about this important software/firmware update, when they were very prompt in sending me notice about the latest fuel pump recall, in addition to BMW USA's notification.I don't have the full details on exactly what it is, but from what they said, it's a major firmware update. Basically they had to hook the bike up and it took about 6 hours to fully download.
I also asked if they could revert to the previous software version, apparently they can not. I guess only the current version is available from BMW corporate.
That's the most plausible suggestion.Sounds like cam timing to me. Maybe they messed with it during valve adjustment......
What he said. I don’t know what reason they gave you for changing all 6 coils, but I can’t see any way for all 6 to be bad. If somehow all 6 were bad I doubt the bike would even run. Something smells like rotten fish in that service departmentBike runs fine. Shop works on bike. Bike doesn’t run fine. Duh…. Doesn’t take a rocket scientist to figure out who is responsible. BTW, just stating the dealer changed all 6 coils tells me he ripped you off! I’d demand the dealer fix the bike NOW! If he says no my next call would be to a lawyer.
All valves were rechecked and remain in spec (see attached). Also bike was already in their shop for six weeks (!!!) and they are at a loss, very frustrating for me obviously. Interesting thought irt the cam timing, can you elaborate on that?What he said. I don’t know what reason they gave you for changing all 6 coils, but I can’t see any way for all 6 to be bad. If somehow all 6 were bad I doubt the bike would even run. Something smells like rotten fish in that service department
The guys are thinking that the tech may have allowed the cam chain to jump a tooth or two, turning the motor back/forth when checking the clearances. It's a possibility, but if it runs cleanly below 7k rpm, then I would tend to look elsewhere first given they have supposedly taken a second look already. Incidentally you still haven't mentioned whether you have all the usual ride modes operating effectively.All valves were rechecked and remain in spec (see attached). Also bike was already in their shop for six weeks (!!!) and they are at a loss, very frustrating for me obviously. Interesting thought irt the cam timing, can you elaborate on that? View attachment 164742 View attachment 164743
Good question, my neutral light was green before, no change there after the work was done.Sounds like cam timing to me. Maybe they messed with it during valve adjustment......
There is no all models all years software update. They are bullshitting you in a major way. Do you remember which color your neutral indicator light was? What is it now? I am asking because there was one big update years ago for bikes all the way to 2015 that affected fueling and ignition to protect the engine from detonation damage to the pistons. The neutral indicator light 'N' changed from beige to green. I had a 2014 that went through this update with no noticeable changes to performance.
I'll attempt that process and get back to you.The guys are thinking that the tech may have allowed the cam chain to jump a tooth or two, turning the motor back/forth when checking the clearances. It's a possibility, but if it runs cleanly below 7k rpm, then I would tend to look elsewhere first given they have supposedly taken a second look already. Incidentally you still haven't mentioned whether you have all the usual ride modes operating effectively.
Anyway, it costs nothing to undertake a throttle reset, in case the tech inadvertently messed with the TPS whilst working on the bike. Even working on the bike at home, it is easy enough to have the ignition on for a while & roll the throttle 3 times, without taking it full open, which reprograms the TPS accordingly. To reset, assuming the TPS is good: -
1. turn ignition "on" but don't start.
2. rotate throttle completely three times (from fully closed to fully open).
3. turn ign. off.
4. Road test the bike & report back.
BTW who gave the instruction to change all the ign coils? Was there a problem misfire or stumble that you reported ?
FWIW, many years ago I bought a Honda Super Slug from a workmate as a cheap commuter. I knew they were pretty uninspiring performance wise, but this one was extra lethargic, although it would pull totally cleanly through most of the rev range before running out of puff.The guys are thinking that the tech may have allowed the cam chain to jump a tooth or two, turning the motor back/forth when checking the clearances. It's a possibility, but if it runs cleanly below 7k rpm, then I would tend to look elsewhere first
