Hi,
I ˋve updated my „B“ with an Audio System 2 Way Component System „M100 Evo2“
I chose it, because it has a fiberglass membrane, so I hope it is somewhat water resistant and it has 3 Ohm, so that it is a little louder even with the stock amp. And it has a very small crossover.
Unfortunately the magnet of the midrange woofer is too big so it does not fit mounted on the inside of the housing like the stock speaker was. But it works if the woofer is mounted on the outside of the housing, as it was on the older K1600s. So I first disassembled the housing and stock speaker. Then I enlarged the speaker cutout a bit with a Dremel Multitool saw so that the basket fits from the outside into it.
Then I drilled the cutout for the tweeter bracket using a step drill
Then I „opened“ carefully the two „nuts“ where the stock speaker is fixed on the upper section. If you look closely at the housing, you can see a little spot where they are molded from the other side and you can carefully drill them open. Now I had already two nuts to fix the midrange woofer from above with the original screws at the original fixing point.
I mounted the speaker in order to see where the other fixing points need to be drilled, marked the other 2 fixing points and drilled them. Now I had all fixing points prepared.
Next I used a hot glue gun and glued in the tweeter bracket and two nuts for the speaker screws which are not at the original positions.
Then I cut off about 1,3 meters from the wiring from crossover to the tweeter. This wire way too long. I fixed the crossover with a velcro almost on the bottom of the housing, assembled the housing again and mounted the tweeter and the midrange woofer. I sealed them in their cutouts with some butyl line. The woofer fits a bit tricky because of its wiring connection port but it works. Fix the screws and ready to go with a high quality 2 way component system
I am very pleased with the sound, even with the stock amp. Especially compared to the poor original speakers.
