Well I finally finished up the install on my 2019 BMW K1600 Grabd América. So I wanted the bike to look completely factory original and stock. That was my first goal. My second goal was to achieve high volume quality sound with as much base as I could get away with on a motorcycle which is what I really wanted
Without spending $2000 on speaker enclosures only from Russia.
I wanted to see if I could come up with an alternative. I came up with the idea from reading all of your posts here. Thank you so much for sharing your research I want to do the same to help others.
so, I can’t believe how loud and clear it is I have strong mid base it’s not deep but it is a very strong midbass it sounds extremely good I had to go to the dealer for a recall and the guy was driving the bike around for a test ride, he asked me if I upgraded the stereo because he said “there’s no way that stereo was stock”. 4 other Techs came over and they were listening to it and they wanted to know what I did. So the BMW techs were impressed. That sounds good enough for me. They were commenting on how impressive it was that it was so clear and the base. Now out riding on the highway, you can still hear the sound, it’s about four times louder than it was and it’s really clear, the highs are clear, the midbass is clear, the mid range is super clear and no more irritating throbbing from the aft top case where that stupid little silly 5 watt 2 ohm subwoofer lived.
So I believe I spent approximately $400 on the complete upgrade, the speakers are water resistant ( kickers) and all the connections were done with heat shrink tubing (to prevent moisture) I even did a special mod so I can take the top case off and used quick disconnects fir the rear speakers. The one thing that was such a pain in the ass for this grand America was the rear speakers! you have to use the front channels as input for the rear channels on your amp and then adjust it with the gain on your 4 ch amp to balance it. So you cannot fade front to rear like before, there was absolutely no way around it. If you’re interested, I’ll take a video of the sound but I’m sure on the phone you will not be able to appreciate it. I could’ve bought much more expensive speakers but those kicker speakers were a really good choice from the research I did as in comparison. They are cheap speakers but they put out a lot of mid base. They are water resistant. Did I mention that they put out a lot of bass for their size? 5 1/4 inch in the front 4 inch in the rear. And they’re cheap enough if I ever blow the speakers it’s really going to be easy to just pop them out and replace them with the same size within an hour you could replace all four of the way I put it back together. Don’t waste your time if you have a grand America trying to tap into the rear inputs to the aft subwoofer amp. It only has three wires and a shielded cable running to plug-in and power the amp which is crossing over the signal internally and the speaker wires coming out of it or split into three sets, two sets of highs and one sub signal. So after talking to Alpine electronics they informed me what to do and it worked.
I spent a lot of time stressing out over trying to tap into the input for the app speakers you had a choice of three wires or six wires for input don’t waste your time. Long post but I hope it helps because I couldn’t find enough information on the grand America and I’m hoping that the next guy will be able to use my research to help.
feel free to contact me I’m happy to help you with anything you have I’ve kept my notes.
