I think I've learned something about the twitchy behavior of my bike. I mentioned in my original post that the tires were correctly inflated at 42 lbs each. I had checked them using a BMW tire gauge that I've had for years and believe is accurate.
I hadn't really paid attention to the readings of the tire pressure monitor built into the bike, since I don't really know how accurate it is. I've thought of it more as a way to detect a leaking tire than as an accurate indication of actual tire pressure. I did notice, however, that it was reading around 3 or 4 lbs lower than my tire gauge, perhaps because its been quite hot here recently and the TPM is temperature compensated and my external gauge is not. Anyway, I decided to pump up the tires until the TPM displayed the proper 42 lbs pressure for both tires.
I only had time for a short ride after pumping up the tires, so I'm not sure if the problem is totally cured, but it is certainly greatly improved. Apparently much, or possibly all of what I've been feeling is flexing of the sidewalls of the tires, allowing the bike to move side to side with respect to the contact patch. I'll take a longer ride tonight to check it out some more.
Assuming this has been the problem, I wonder what will happen when the weather gets colder. The temperature compensated TPM will continue to read the same, but the actual air pressure in the tires will be reduced, perhaps as low as it actually had been before I pumped the tires up. Wouldn't that mean the problem would return even though the TPM is still reading the correct pressure?
