Thanks, I will do further tests combining different pins if you have brake lights on yoursMy GA topcase is running light and brake light. No turn signals. Has 7 pin connector. I don't have a photo of it.
I actually just started another post regarding this. I just got a 2018 GA and it has only Brake Light for the top case. I am also looking for information to convert it to Running Light and Brake Light.Can someone with a GA confirm what functions the topcase lights do (running, brake, flashers, etc) and if their connector has 7 pins (picture) ?
thanks
Thank you. I will do it tomorrow itselfFor the K1600GT/GTL the Skene IQ-160 converts the top case 'brake only' light to run/brake. Pretty good bet it will work with the GA. I'd give them a call/email.
http://www.lights.skenedesign.com/K1600-IQ-160.shtml
I asked the dealer and they said the GA is not programmed like the B, thus why the connector does not have all the lights.I actually just started another post regarding this. I just got a 2018 GA and it has only Brake Light for the top case. I am also looking for information to convert it to Running Light and Brake Light.
If anyone has done that successfully, kindly share the details.
Clearwater is the Cadillac of all these.A skeene is a good option, but a better option, if you think you'll be doing more stuff, is a Hex ezCan (or Denali CanSmart). Why have 3-4 modules you have to install vs. 1 that does everything in a tiny clean package? It costs a bit more, but if you plan to add driving lights and other accessories, it is the better way to go.
All of these you have to cobble and splice wires. Makes no sense. Clearwater you do none of that. Very clean and looks factoryThe GA has a top case and it has a plug powering the top case similar to the GT/GTL, color code may be different but the wires will be the same powering the brake light. I'd bet a dime a to a dollar the Skene IQ160 will do the trick.
I had the Clearwater. . Functionally is certainly similar. But, I sold the Clearwater CanOpener for the ezCan. If the Clearwater is the Cadillac, then the exCan is the Ferrari.Clearwater is the Cadillac of all these.
