I went with a very inexpensive GS-100A module that someone else on the forum had used. Easy-peasy and works great for the eye catching quick flash when brakes are applied. Not fancy, no turn indicator, just 4 quick flashes, 4 slow flashes, then solid brake light. It tucks in right behind the factory brake light insert in the top box.
https://www.amazon.com/iJDMTOY-GS-1...=2025&creative=165953&creativeASIN=B00N44WLXS
Is it right, you put it between the LED-light strip before its connected to the box by srews or do you put the module into the case outside the "LED cover"? Hard to describe...
a) LED - GS-100A - topcase mount - hole - cabling to the connector inside the topcase 2 pin
b) LED - topcase mount - hole - GS-110A - cabling to the connector inside the topcase 2pin
I have purchased this module a while ago, but fear:surprise: to cut cable and mount it so far. What I want do is just to have the topcase light flashing and the motorcycles untached because of German regulations.
Thanks in advance.
