Im getting ready to change the plugs and want to know which plugs people are using.
Cant find plugs on line.
Thanks
Thanks
anti seize for newer plugs is a big no. Apart from that, a little bit gets by accident on the tip of the electrode and you are in for an early failurewith the engine warm or hot at least remove the plugs and re-install them with anti-seize. A plug left in an aluminum head too long can seize the threads and when you do get around to removing them you strip the threads and then you have 10x the worry and $'s involved if you had just replaced them according to the service manual. If you are tearing it down enough to get to the plugs you may was well put new ones in.
I for one want the top performance and replacing the plugs if that keeps it at 100% is what I will do.
Cheers.
