For several months I have had a problem starting my bike. I replaced the battery and I also replaced the starter relay. Both intermittently seemed to have "fixed" the problem, but only temperately. I finally took it to the local shop and they had the bike for over a week. They said that it seemed like the wires going to the battery terminals were loose and tightened them up. Meanwhile they started the bike numerous times and it would not fail. They found nothing seriously wrong so I picked up the bike and rode it home.
When I tried to start the bike this morning, it would not start. Battery read 13.25 volts so I knew it wasn't the battery. Everything was tight but it still would not start.
When I stop my motorcycle, I generally leave it in first gear and bring down the kickstand. I've done it this way forever. Just for grins, I put the bike in Neutral and she fired right up. I put her back in first gear with the clutch in and she would not start. I put her in second gear, clutch in, and she would not start. Putting her in N and she fired up. I think I've figured out the problem.
It there a part or switch that might be shorting out that keeps her from starting in gear. even though the clutch is engaged?
