Garmin'ish Nav 4 Question
1.7K views 5 replies 4 participants last post by  katnapinn
Hey All,
I have a Nav 4 on my GT. Is it possible to create a route with multiple points on my computer and then upload it all as one trip and route? Right now on long rides I put in my final destination and then just one stop along the way that gets the route I want to take at least CLOSE to what I would want.
Sometimes that Nav 4 is just too effecient of a route planner. I have specific roads I like to take some times. Is this possible?
Thanks.
#3 ·
Yes, possible and SOP for a lot of us.
Garmin has two programs that will let you do this: BaseCamp and MapSource. BaseCamp is the "way forward" as MapSource is just in maintenance mode. So since you haven't used either, I would strongly suggest you look at BaseCamp. It also provides some nice features for organizing your data that MapSource does not.
BaseCamp is also available for the Mac; MapSource is PC only.
You can get BaseCamp here.
Here are some writeups that IMO are the best place to start learning:
http://garmin-mapsource.wikispaces.com/BaseCamp
There are also some very basic video tutorials that Garmin has done that you can find here.
I made a little demo for some of my friends showing how to do some things with Track files; a little different from your specific need at this point, but it will give you a feel for some other things that BaseCamp can do.
I have a little more time now...here's a little more detail.
The file Current.gpx in Nav/Garmin/GPX contains your current favorites, custom routes, and active track files.
If you use BaseCamp, it puts data onto your device via the file Temp.gpx in that folder. Those items will automatically get added to your device's favorites and custom routes upon the next device boot-up.
I believe that any other gpx file in the folder will get automatically loaded as favorites as well. At least gpx files produced by Garmin software. I'm not 100% sure about this, though.
Data (favorites, routes) in any other .gpx files in that folder, or on your memory card in Card/Garmin/GPX, will be available for import under the device's Tools:User Data:Import:[favorites or routes].
If you delete your favorites and custom routes, but those items are in gpx files that are still out there, they can be imported again.
If upon bootup, the device sees a new gpx file out on your memory card, it will tell you it's there and ask you if you want to import. But it only does this once when it thinks there's something new out there. Thereafter, it is still out there and available, but you will have to explicitly import it.
The exception here is stuff in Temp.gpx. Whenever you move items from BaseCamp to your device, BC recreates that file with only the new items you're moving. So any stuff you moved previously from BC, then deleted from favorites, will no longer be there and available for re-importing if you've moved anything from BC since. So don't count on that file as a place to save anything (that's why they call it "temp" I suppose).
I know a lot of folks like to put gpx files out on the memory card so the data can be loaded later. Or use it as a backup. I think RL uses this approach.
Be aware this is all BaseCamp. My time with Garmin is pretty recent, so I just started with BC. I'm sure the MapSource concepts are similar, but the details will no doubt be different.
