21 - 40 of 199 Posts
Discussion starter · #27 ·
I guess those that have the dashboard bezel/shroud for the BMW Nav IV will need to buy the larger one from the M/Y's that had the NAV VI - is that correct?
The Nav V and Nav VI screen sizes are exactly the same. The only difference is the screen is shifted 2mm right on the Nav VI (relative to the mount) which is why BMW has two bezels (dashes). I could have split the difference but then the screen is off by 1mm on both dashes. But I have decided to do what I did with the XT mount and make two versions. When properly centered, the Carpuride will have about 1.5mm dead space on the left and right so the entire display is visible.
My printed circuit boards for the mount should be here today. Not sure why it took DHL 7 days to deliver them... Once I verify (or adjust) the PCB fit into the mount I should have some ready to go.
Discussion starter · #29 ·
Guys I have a limited quantity of these mounts now. Because of the list of those wanting one from a Facebook post I made, I haven't opened up orders on my website yet. But if some of those interested here want one, I'll ship to you all first. Just message me and I can send you a payment link.
What electrical connector/plug does the Carpuride use - the connectors in the first post don't look like the final version.
Discussion starter · #32 ·
It has a permanently installed 4 inch long pigtail with a two pin barrel connector. Just need to cut off the connector and insert the wires into my supplied crimp connector (or if so inclined, solder and heat shrink). Details are here. https://coyote-industries.com/Carpuride Instructions.pdf
The inline splice is solid and very easy to do.
Discussion starter · #36 ·
What about this one?
Doesnt look bad, more expensive but good looking.
Enjoy bricos!
Absolutely wonderful, I'm going to buy it.
Thanks for the information.
